Universal monitor bracket for Vewlix
Just got notice of it being shipped. Woohoo!
And now it states the shipment is canceled. Despite emails to @Hadouken Arcade, no idea what is going on. I understand doing this type of stuff is difficult, but being in the dark like this is frustrating. I don't mind the delay at all, I just wish I knew what was going on.
Hadouken replied and the package is on its way.
PSA - unless you hack your HA bracket, the newer LG gaming monitors with a metal piece sticking out at the back is not compatible with the Rev B bracket.
Edit: it seems the Rev D bracket already caters for this
Monitor back looks like this
In preparation for next gen fighters, I purchased 2x LG 32GN600 to go on both of my Chewlix's.
Due to the size and location of the mount, the bracket that the vesa mount bolts on to physically will not fit the bracket
This is where I had to get the drill and jigsaw out. I had to cut off a hole in the bracket (yellow) for it to stick out and I also had to cut the tabs (red) which removes my 200mm compatibility for monitors.
I probably could've removed the stand holder, but I had great difficulty trying to decase the monitor and I was too scared to break it. I was OK with hacking the bracket up as expensive as it was. I'm not sure if all new LG monitors are like this, but I know the older QHD, 165hz LG's weren't.
Once those two "mods" were done, it was simple enough to install again
Now it's time to calibrate the monitor to my preference, take notes of the settings so I can rinse and repeat the same process for the other cab.
So @Hadouken Arcade, if you ever do a newer revision, it might be worthwhile to extend that opening you have to where I've shown with yellow outline in the pic earlier. I don't think it'll affect the mount structurally, but I'm also not sure how that impacts the Vewlix version as I know it's got another piece that goes on top.
One of my LG monitors had that thing too. I decased the monitor and removed it. It was really easy to do, for what it's worth. Also allows you to dangle the nub out too. Is that ok to say here?
Yeah, I understand, it definitely feels a little dicey. I got mine from Costco, which has the easiest return policy on the planet, so the stakes were pretty low in my case.
Oh man, pics and video, we need to see how awesome this looks. Are you going to use it with the retrotink 4k?
This is with Mister at 1080p. I think I am going to get beat down in SF6 in 4k mostly :D. I doubt any pictures will do it justice. I am just reporting that the monitor fits in the brackets.
Can anyone confirm fitment / compatibility of hadouken bracket with Vewlix Diamond Black?
Hey folks, for people in Europe how much did the brackets ended up costing you? I'm assuming these are being sent from the states.
I have a chewlix with a Gigabyte M32U 4k 144hz on it, which has been a sweet SF6 setup, but the way i have it secured in there, is a bit precarious for my tastes.
It is writing pre order on Hadoulen arcade so if order when could it be shipped ?
Hey, just ordered one of these to put a 32GP850-B in my new FC that just came in and I'm not seeing a changelog from C to D in this thread, but the OP does mention
This next design will be non-drill version. At the beginning of the design, I was hesitated to use the original M3 screw size but since I have confirmed enough installation myself (roughly 20 cabs so far), I’m more comfortable switching to M3.
and
I'm also creating another optional part to secure the glass in the monitor frame for L, F, FC, orange and diamond black. This will also address the monitor glass being able to push in on the corner.
A couple of questions:
Is Rev D confirmed drillless? I do notice on the store page that under "required tools" it just lists the screwdrivers.
The monitor I removed (Sanwa TH32A-1) did not have the glass sandwiched between the outside of the solid inner frame and the four piece rails that attach to them as in the example video, but rather the glass was adhered to the panel itself (sitting behind both the frame and the rails) and I had to carefully pry it off and clean the residue off. I was planning to use some VHB tape to mount the glass directly to the inner frame, but would this optional part provide a better, less sticky solution? Is this also included in the order (I didn't see any optional parts listed aside from the brackets for specific monitor models that aren't the one I have)?
@Hadouken Arcade - As I purchased a revision D from you, for my Diamond Black, and had to 3d-print glass spacers AND silicone seal the glass to the bezel, in my install.....I'm VERY interested in this now optional part to secure the glass properly.
Can you espouse a bit more on that, and let us know if there's a discount on that individual part, for people who've already purchased Rev D from you?
Thanks!
I finally got around to both rotating my Viewlix back to Horizontal and installing the Haudoken bracket on my 32" OLED FO32U2
After problems with other models @ItsBobDudes reached out and recommended an OLED variant of a Gigabyte model that worked for him.
Unfortunately. The back was to fat for the bracket just like the other OLED brands. So I got my Dremel out and carefully problem solved that by cutting away the backing past the flush point.
It wasn't pretty but its safely shelled where no on can see it.
The image quality is night and day. It's exactly what I thought it would be with perfect blacks and juicy colors.
I decided to run a PS5 instead of the switch and bought a cheap SFVI art set from a facebook group.
