Update. Fixed the two bad ones.
Not a problem, I can add in a mounting location for a header to extend/mount the volume pot on a separate pcb.Is there any difference in sound output levels between Batman and other STV games when using the sound mixing setup via RCAs?
If there is and you need to adjust per game then a remote mounted volume control likely suits those of us who have their boards buried deep in a cabinet. (But if it’s set once and forget then the adapter option would be easier)
The button remap is only for the batman game, so you need to switch it back for the other games. This one unfortunately is not worth trying to extend off the board, we are talking about 24 connections. and getting into other remapping setups/extenders via multiplexers, mcus, etc...just doesn't make sense as it will drive up the cost/complexity.Does the button remapping have any negative affect on other games? Same reason as above, trying to see if it’s set and forget, or something that needs to be swapped each time playing Batman and then back for other games.
Dont see a reason why it should not work, if your sound board has the jacks, or you can add them/solder connections to it, it should work.@Derick2k can I use your new PCB with an OEM Batman sound board? If so, I'm going to hold off ordering the new SB with the audio out.
Don’t change the audio location based solely off me, I’ve got a few external/remote volume control options so was trying to weigh up which one made the most sense.Not a problem, I can add in a mounting location for a header to extend/mount the volume pot on a separate pcb.
Added an extension header for the volume pot. Again, you only really need this if the amp in your cab doesnt have volume control or you want to control volume from somewhere else.If there is and you need to adjust per game then a remote mounted volume control likely suits those of us who have their boards buried deep in a cabinet. (But if it’s set once and forget then the adapter option would be easier)
No reason why you shouldntthat is gorgeous and i wish i could afford it
I know its going to look amazing!Looks fantastic! It sounds like for the enclosure I will be going with black and gold (maybe a subtle white accent).
What do you mean bro? Short on cash? I can get you one, don't sweat it!that is gorgeous and i wish i could afford it
short answer, yes. its my own fault tho. i appreciate the offer but maybe ill have time to recoup before it goes on sale. if its a couple weeks i should be fine.What do you mean bro? Short on cash? I can get you one, don't sweat it!
Can you you check tracking numbers for me because i have not receive it yet ? Thank You.Add me to the list with RCA version. Thank You.
