Thanks!Hi,great work @mypinballs !
Side note, I've gotten hold of a F3 Taito Cup Finals PCB but it is missing the PAL chip at IC28. I thought it was dumped and uploaded to jammarcade.net but I can't find the file?
IC28 is labelled as D29-14 which I think originated from Arabian magic. The file is available at jamma-arcade under the hat trick hero'93 title as thats the alternative name for cup finals
You will need a GAl20v8 gal which are hard to get to use the file in its original form though
If you are stuck I can help you and supply a chip/file for use with a modern ATF22V10 gal. There is some conversion needed as the 22v10 ics are larger in size and so you can't just use the original file with the newer ics.
I don't have any GAL20V8 chips around but i do have GAL22V10d. Would it be possible to make that work?
