Available here - https://rgbslab.com/products/has-v4-2About
Home Arcade System, “HAS” for short, is a device that allows you to play original arcade game PCBs without the need of owning a real arcade cabinet. Think of it as of a game console, only instead of cartridges or discs, you insert arcade game PCBs. The latest version is V4.2.General
- JAMMA, JAMMA+, and "CHAMMA" compatible
- Built-in voltmeter (selectable +5 V/+12 V)
- Comes with a plexiglass case and a power supply harness
- 142 x 88 x 35 mm total size with the plexiglass case (133 x 74 mm PCB size)
- Modular build; can be upgraded using dedicated modules that sit "on top" of the HAS
Controls
- DB15 controller ports (NeoGeo compatible, pinout extended to support buttons 5 and 6)
- Programmable button layout
- Programmable rapid-fire (VSync synchronized or asynchronous, 6 different fire rates)
- Buttons 1-6 on the JAMMA connector (buttons 4-6 can be disabled)
- Buttons 4-6 on the JST-XH 6 pin “kick harness” connector
- Test and Service buttons
Audio-Video
- Video output: Fully buffered 0.3-1 Vp-p 75 Ohm RGB (0.7 Vp-p nominal at the default potentiometer position), CSync 0.35 Vp-p 75 Ohm (can be set to TTL ~5 Vp-p 470 Ohm impedance)
- Audio output: Unbalanced, attenuated to line level; stereo support for the NeoGeo MVS
- Video on an 8 pin mini-DIN connector (XRGB mini/NESRGB pinout); audio on a 3.5 mm stereo connector or the 8 pin mini-DIN if the 3.5 mm stereo connector is not in use
- CSync Regeneration feature
- Selectable raw JAMMA/unprocessed CSync
- Selectable Video Low Pass Filter
- Brightness regulation using a single knob
- Optional HSync and VSync outputs on the PCB (~5 Vp-p, TTL)
- Can be upgraded to output video through an HD-15 connector (requires an HD-15 module)
Power
- Power is delivered through a 6 pin JST-VH power connector (GND, +5 V, +12 V, -5 V)
More pictures
Various accessories were released for the HAS. For availability please visit - https://rgbslab.com/collections/products
