This has me interested but I have 2 questions....@ekorz has shipped a Wargods pcb set to me to see if I can make this CF kit happen. Multiple people have asked in the past month if I can make it happen, so let's do this.
really hoping that something good comes@ekorz has shipped a Wargods pcb set to me to see if I can make this CF kit happen. Multiple people have asked in the past month if I can make it happen, so let's do this.
These are a great solution and are working very reliably on my Battle Gear 2 boards.1. Any chance we could use an IDE DOM instead of a CF adapter? I feel like they're a lot more compact and generally more reliable solution.
I have one in my KI2 and love it.These are a great solution and are working very reliably on my Battle Gear 2 boards.
I had only recently seen these IDE DOM devices when I bought an IDE SSD (60gb) for logic analzyer. Never even thought of using them with arcade games, but good idea. Where do you recommend buying them, what brand?1. Any chance we could use an IDE DOM instead of a CF adapter? I feel like they're a lot more compact and generally more reliable solution.
Don't think so, because Cruis'n uses ROMs where WarGods uses IDE drive2. would it be possible to convert a Cruis'n USA or Cruis'n World to WarGods?
Yes I already had you in mind for someone who wants and needs a kitIf so Ill be first in line to pick up a couple of flash drives from you for my boards
Awesome!!I had only recently seen these IDE DOM devices when I bought an IDE SSD (60gb) for logic analzyer. Never even thought of using them with arcade games, but good idea. Where do you recommend buying them, what brand?1. Any chance we could use an IDE DOM instead of a CF adapter? I feel like they're a lot more compact and generally more reliable solution.
@Mitsurugi-w is correct that if I can get a CF to boot, then any other device should be good to go.
The boot rom checks the connected drive to see if the cylinder/heads/sector values match what is hard coded. Two ways to patch: completely remove the checks, or change the values to support a specific media type/density.
But will keep it in mind to support any IDE device
I don't have any recommendations for this. they do seem to carry them on amazon but I have no idea if those are any good. I only have the one on my KI2 and that kit was put together by someone else (I forget who at this point).Where do you recommend buying them, what brand?
omg…Boardset arrived last week, waiting for the DOM package as the eBay seller decided to wait 12 days to ship the item
This is some great info to add.sorry to add to an old thread , lots of talk about all kinds of random stuff in here. I have made several Wargods drives, (NOT CF). The reason is Wargods looks for a specific drive SIZE! Some drives let you change the drive size therefore I have made 20GB drives boot no problem. CF cards don't have the ability to force a size so it doesn't work. So what you need to look for in the boot sequence is how to remove the size check.
