I was in for 2 of these but now he has released the files i'll probably just order some pcbs and knock my own up
Wasn't planning to, don't really see the point. I've a few Saturn and DC consoles and have never had an issue with their power supplies.
you will see the use case once you try to use a 100V Saturn in a 220V country (for example) :D
oops someone else posted that he released everything .. nothing to see here..
It's very easy to modify the power supply for a DC from 100V to 220V :) I've done it a few times now. A capacitor swap and a couple of resistors need to be added depending on PSU revision.
I assume the Saturn is similar but I've not looked at that
Its all.in the zip. They are in open office spreadsheet format.
I initially ordered one of each.
So I'm still keen for one of each if someone makes them.
I remember on his updates he was dealing for a very long time with a power issue. His problems began from this issue which took him quite updates with stationary situation. I don't remember him solving it before the supplier started ignoring him. If there's a mistake in the design we better check this before spreading the files and frying Saturns.
Chris released the files and specifics:
https://github.com/PSUThings/PSU
I already have the DreamPSU, but I think I will produce some of the Saturn ones if nobody else is going for a run here.. :)
Is there a list of components to order for this? I don't see a components list, mind, I'm pretty noob at using github.
Thanks. I personally don't like to use spreadsheet software (I once had a bad experience!)
So here's a copy and paste list of the parts, for posterity:
DreamPSU Component list:
RefValueTechnologyFootprintManufactureManufacture Part NumberQuantity
R1,R610.2k,1%,1/10wSMD0603YageoRC0603FR-0710K2L2
R4,R822.1k,1%,1/10wSMD0603YageoRC0603FR-0722K1L2
R673.2k,1%,1/10wSMD0603YageoRC0603FR-0773K2L1
R3,R7100KΩ (1003) ±1%SMD0603Yageo0603WAF1003T5E2
R2124k,1%,1/10wSMD0603YageoRC0603FR-07124KL1
C10,C2100nF (104) ±10% 50VSMD0603YageoCC0603KRX7R9BB1042
C16,C81uF (105) ±10% 50VSMD0603MuRataCL10A105KB8NNNC2
C17,C9CAP CER 8200PF 50V X7RSMD0603MuRataGRM188R71H822KA01D2
C11,C310pF (100) ±5% 50VSMD0603KemetCL10C100JB8NNNC2
C4,C5,C12,C1310uF (106) ±10% 50VSMD1206MuRataCL31A106KBHNNNE4
C14,C15,C6,C7,C122uF (226) ±20% 25VSMD0805SamsungCL21A226MAQNNNE5
L2,L1Inductor 2.5uHSMD7.60mm x 6.90mmPulsePA4341.252NLT2
U1,U3IC REG BUCK ADJ 5.5ASMD14-TSSOPTexas InstrumentsTPS54525PWPR2
JP32 Positions Header Right Angle Connector 3.96mmTHT7.92mm x 8.6mmTE Connectivity647676-21
JP23 Positions Header Connector 7.92mmTHT11.9mm x 8.5mmTE Connectivity1-1123724-21
JP16 Position, Bottom Entry Connector 3.96mmTHT23.7mm x 11.90mmMolex00095230621
J1, J2, J3, J42 Positions Header Connector 2.54mmTHT1x2-2.5mm6030916A 1x2 Male4
REAR POWER JACKFC6814461
Saturn:
R11,R510.2k,1%,1/10wSMD0603YageoRC0603FR-0710K2L2
R922.1k,1%,1/10wSMD0603YageoRC0603FR-0722K1L1
R12100KΩ (1003) ±1%SMD0603Yageo0603WAF1003T5E1
R10124k,1%,1/10wSMD0603YageoRC0603FR-07124KL1
R633.2k,1%,1/10wSMD0603YageoRC0603FR-0733K2L1
R154.9k,1%,1/10wSMD0603YageoRC0603FR-0754K9L1
C1747µF ±20% 6.3V 1206SMD1206Samsung Electro-MechanicsCL31A476MQHNNWE1
C2,C16,C23100nF (104) ±10% 50VSMD0603YageoCC0603KRX7R9BB1043
C1,C211uF (105) ±10% 50VSMD0603MuRataCL10A105KB8NNNC2
C22CAP CER 8200PF 50V X7RSMD0603MuRataGRM188R71H822KA01D1
C910pF (100) ±5% 50VSMD0603KemetCL10C100JB8NNNC1
C19,C2010uF (106) ±10% 50VSMD1206MuRataCL31A106KBHNNNE2
C10,C15,C18,C2422uF (226) ±20% 25VSMD0805SamsungCL21A226MAQNNNE4
L2,L3Inductor 2.5uHSMD7.60mm x 6.90mmPulsePA4341.252NLT2
U6Buck Switching RegulatorSMDTSOT-23-6Texas InstrumentsTPS5632001
U2IC REG BUCK ADJ 5.5ASMD14-TSSOPTexas InstrumentsTPS54525PWPR1
U5Linear Voltage RegulatorSMDSOT-89-3STMicroelectronicsL78L09ABUTR1
SW1Slide Switch SPDT Surface Mount, Right AngleSMD8mmx6mmC&KAYZ0102AGRLC1
JP52 Positions Header Right Angle Connector 3.96mmTHT7.92mm x 8.6mmTE Connectivity647676-21
JP43 Positions Header Connector 7.92mmTHT11.9mm x 8.5mmTE Connectivity1-1123724-21
J5,J6,J72 Positions Header Connector 2.54mmTHT1x2-2.5mm6030916A 1x2 Male3
J15 Positions Header Connector 2.54mmTHT1x5-2.54mmKF2510-5A-2.54MM1
JP15 Position, Bottom Entry Connector 3.96mmTHT20.85mm x 11.90mmMolex09-48-40591
BOMS converted in XLS format to be able little bit easy when you want to use mouser , digikey or other supplier.
  • DreamPSU & SaturnPSU BOM.zip
I'm pretty sure it came down to bad/fake Texas Inatrument chips the assembler was using. They ghosted him when trying to get them replaced.
Is it just me or is there not silk screen to indicate where the parts go?
Anyone want to group buy the PCB's? I only need one each.
Also, I am seeing that some folks have started producing these already. They are on eBay already. Inertial Computing sells them, etc.
Interesting, got a link?
I have ordered 10 of each together with @PascalP but I have to say it's difficult to match Chris' price in these kind of small quantities. Also the import fees are ridiculous for both the PCB's and the other parts. I can only match that price if I count nothing at all for assembly. Probably will be selling them as DYI kits for around the €40-€45 mark sadly :(
Yeah don’t really know how they can offer them for that price...
As @Sp33dFr34k says, we put in some orders for pcb’s, 3D prints and parts from Digikey and are in for about $45 each just in parts...
That is also including our local taxes, import fees etc
Hopefully we get everything soon, assemble 2 kits for ourselves and sell off the remaining 8 kits, either assembled or DIY...
@Sp33dFr34k and @PascalP - i might be in for 2 kits since i wont be getting the ones i ordered...
