Sp33dFr34k
That was in the other part of my message, 5a should cover itI think a more powerful PSU should fix the issue.The issue is that you might want to tweak 5v between normal carts and your multicart, so you'd need a PSU with an adjustable 5v.
I wasn't aware there were 5v (I mean 5v output only here) adjustable PSU's, do you have an example of a good one for our friend here?Since you only need 5V >5A there are tons of power supplies with adjustable voltages for <$10. Just have a look on Aliexpress. You'll just need to put lead on it an cut the wire with connector of your old power supply and reuse it. No modding the console. If you're not confident wiring up a power supply yourself you can also try and find a plugin LED power supply with the same connector for plugging into the Console.
While the Suzo Happ is a perfectly fine PSU, it would be a bit overkill in his situation and kinda kill the purpose of his consolized MVS.A Suzo Happ Power Pro like @jassin000 linked would be a good choice. I use the Ultimate, which is total overkill. There are also some decent Chinese clones (like this) that will save some money if you're on a budget. You can get those through eBay or Aliexpress direct from China.
