Add another $5, the side of the interconnect board closer to the main PCB of the kit is not inserted enough IMHO.Honestly I still have my $5 on the interconnect board being seated too high...
That could be a PAL issue or a problem with the multi or the jumpers not cut properyl. Even a bad microSD could load the contents bad to the microSD.Hi everyone,
I installed my multi kit and it worked great for maybe 10-15 minutes when I was testing it out. Came back a few hours later to play and the sound was all wonky, still recognizable but playing the wrong sounds at the right time.
I’ve uninstalled and reinstalled and checked for broken pins but I can’t find anything wrong. I’m running a rev 4 with a g pal. Where should I start?
I noticed people talking about jumpers before, but the second step is literally “there is no need to modify the jumper configuration”
Thanks
added photos of install
https://imgur.com/a/1o3ja1b
If you downloaded the rollup pack "MVC_unlocked" is decrypted.Thank you
Do you have a link to dl a decrypted rom?
Best regards
sorry but I found nowhere.If you downloaded the rollup pack "MVC_unlocked" is decrypted.Thank you
Best regards
get the old rollup pack that has everything unlocked... or try one of the hacks that have been put together.sorry but I found nowhere.I have only encrypted.
