With Freesync, you'll even play the games with the correct refresh rates.Wowww....That exact solution (that looks like stock monitor) is highly needed for modern (PC/Consoles) arcade type gaming at higher resolution than 1080p and MAME with the right CRT filter. A 4k monitor would be the way to go.
Oh good point. Would this also work for G-sync monitors?With Freesync, you'll even play the games with the correct refresh rates.Wowww....That exact solution (that looks like stock monitor) is highly needed for modern (PC/Consoles) arcade type gaming at higher resolution than 1080p and MAME with the right CRT filter. A 4k monitor would be the way to go.
