That's actually a great question. Would like to hear if anyone has done any testing on this.out of curiosity, does the brook neogeo to ps4 adapters work? Since undamned's db15s are out of the limelight for a bit, im curious if they will work?
How does this work? Wouldn't I end up with qsound plus the audio through the minidin if I plugged qsound into the etim scart adapter?Can feed stereo audio from the RCA output of CPS2 (and other games that support external stereo output) to the 3.5mm socket of the DIN 8 / scart kit. Easy no fuss way of enjoying stereo audio.
Nope. Audio from the jamma edge never gets passed through. The 3.5mm audio input of the eTim scart kit is switched and therefore cuts audio from the DIN input.How does this work? Wouldn't I end up with qsound plus the audio through the minidin if I plugged qsound into the etim scart adapter?Can feed stereo audio from the RCA output of CPS2 (and other games that support external stereo output) to the 3.5mm socket of the DIN 8 / scart kit. Easy no fuss way of enjoying stereo audio.
Ahh! I noticed that I get audio on the minidin but when I plugged in the audio jack it got disabled.Audio from the Minigun DIN output (jamma edge) / eTim DIN input is disconnected due to the 3.5mm audio input of the eTim adapter cutting audio to the DIN.
Perfect and easy solution.
Does it work with 6-button games despite being a Neo Geo adapter?I tested out the Brook Neo Geo adapter with a PS3 controller. It worked great in my limited testing. I didnt even realize that you initally plug your controller into it with USB and then you can disconnect the usb and use the PS3 controller wireless! Instructions say you can reassign buttons as well, but I didnt test that out.
i have the brook PS3/4 to neo geo adapter and it does work with the minigun. I have v2.1 of the minigun.out of curiosity, does the brook neogeo to ps4 adapters work? Since undamned's db15s are out of the limelight for a bit, im curious if they will work?
Just to be sure: i run the RGC mini din 8 to Scart for my minigun V1.7. It does not have 3.5mm input.Nope. Audio from the jamma edge never gets passed through. The 3.5mm audio input of the eTim scart kit is switched and therefore cuts audio from the DIN input.
Simply run a mini DIN 8 cable from the Minigun to the eTim adapter. This takes care of video.
Run a twin RCA to 3.5mm connector from the CPS2 RCA output to the eTim adapter 3.5mm audio input, boom stereo audio output over whatever your eTim scart adapter is connected to.
Whats the Booster converter (DC-DC Converter) in that for? Do you need to put it in?We've touched on this topic before, but as a reminder these mini DIN 8 to RGB scart kits from eTim are a great way to connect the video and audio of the Minigun Supergun to a monitor / OSSC etc.
The included DIN 8 cable isn't very good and best replaced with a higher quality cable.
The advantages being:
Proper scart voltage output on pins 8 and 16 for automatic RGB selection, switching and 4:3 aspect ratio.
Can run audio down the mini DIN 8 cable or separately via a 3.5mm stereo audio cable.
I mean, I would use the Undamned converter if it was available, but it is not. As I don't really play many 5/6 button games, the only thing that seems interesting from the things you mentioned is the "simultaneous button presses" issue. Could you elaborate on that?I would not recommend using the Brooks Ps3/PS4 adapter for the minigun. First off the adapter has many issues including issues with simultaneous button presses (Throws for instance in Tekken) and has a lack of functionality (Can't save custom reprogrammed button profiles). Also this adapter DOES NOT SUPPORT 5or6 BUTTONS! Even though on Brooks and other websites it claims to support kick buttons it in fact does not. It only it meant to be used with a NeoGeo and limits itself to 4 buttons. Also the instructions you get with the adapter are wrong and Brooks hasn't bothered to fix them in the past 2 years.
The Undamned adapter is what I would recommend but seems current orders are on hiatus for awhile (UD-USB Decoders) .
Thanks man!In your scenario, you'd want to:
Run the RGC cable as per normal.
Insert a 3.5mm cable / adapter into the Minigun 3.5mm connector. This will cut audio to the Minigun DIN. You don't need to connect the opposing end to anything, it's just being inserted into the Minigun 3.5mm connector to disable audio being output over the DIN.
Something like this for example:
Feed the CPS2 RCA output into your amp.
You can't disable audio from the jamma edge via the CPS2 service menu.
