avramce
Hmm, so just throw the cSync input into a LM1881? Any changes necessary to the typically usages in the docmentation?
[PDF]
LM1881 Video Sync Separator - Texas Instruments
https://www.ti.com/lit/ds/symlink/lm1881.pdf
For my mini9 board, I just added pots and a spot for a 470ohm on the sync line as a bare minimum if someone wanted to get something working off the output from the JAMMA edge, should I remove the 75ohm on the RGB boards output and use something like 100ohm trimmers on the breakout board to allow individual adjustments to the lines if desired:
[PDF]
