So I just hooked the Extractor up and just want to confirm by
@Axun
if didn't missconnect anything
So I put the Cps2.3 Kickharness in the EXT pinout on the Extractor
Then I use the Player 1 EXT PCB hook up another Cps2.3 Kickharness that goes into the cab
Hook up RGB out, Speakers and Player2 inputs to the P2 ext board.
Hook up another Cp2.3 Kickarness to the P2 Board that leads into the cabinet ( I did reuse the same harness from the P1 picture since I ran out of cables)
Am I doing this right?
I also did a Imgur post with descriptions here
https://imgur.com/a/gQdcPKo
Apart from the Brightness issue that has been already adressed I ran some quirks
B4 and B6 simultaniesly pressed, on the player 2 side everything is fine.
But I guess that's just my wiring since I have B4 and B5 loomed together so I don't always have to mount and dismount Kickharness in the CP.
We switch games very often.
I hooked up an Atomiswave that ran absolutly fine on both player sides. But I noticed that the IMages goes up even brighter (no surprise here) on 31khz
Also I find it a bit fiddly to flip the switch for the Kickbutton on the Jamma extractor.
Which determine if your B4-B6 come from External or Jamma Harness. We often switch games so this is a bit of a downer.
My Questions apart from the hook up:
Would there be a way to eliminate the switches and let it just accept anything that goes through?
Will your updated Jamma Extractor version take in account for 31khz on the Jamma Edge too?
