Put me down for 2x spinners and the CPO. Will the CPO fit a naomi cab?
Great job to all involved.
We are on 91Hows pre order going?
I bet a lot of people are waiting for an announcement on the adapters for the CPS Multi?
Support for spinners is available. You need an extra PCB that plugs in the multi. I didnt want to delay the project anymore and make the final multi more expensive, so people who need that PCB because they want to play with spinners, can get it from @Mitsurugi-w.
You want me to work on it again extra 6 month work?Probably a silly question but If you haven't started production run on it yet, would it be better just to redesign it to a shorter version? That way people wont be thrown off by the idea that it may not fit in their cabs?
I have never seen the shorter version of spinner.That's a shame. I have pre-ordered spinners already but I was also looking forward to buying a shorter variant as well.
Is the injection molded parts that different? I was under the impression that it was mostly an identical design just with walls and shafts shorter in length.
I think shorter version would sell more. if we could get only 1 version, shorter version would be the better option. as it seems a lot of people are afraid to order due to fitment concerns.İf this one doesnt sell enough, do you think shorter version will sell?
80mm in height should be more than enough, I measured my spinner installed in a vewlix at 78mmIf anyone can confirm that these will fit inside an Egret 2, then I'll place my order immediately.
The JP version is shorter, but its also missing some parts the US one has. The knobs are different as well, not sure if the weight is the same also.Is there actually a short version? Or is everyone speculating here? I'm pretty sure that Capcom only made one spinner with different topper types.
Please correct me if I am wrong. @manimani, when you tested on an Egret, was everything working fine?
Same as mitsu. Will get my order in asap.I will eventually order two of these but I just currently don't have the money. As soon as I do I will order.
