Ah I see, I jumped ahead in the thread to see the paint job.It wasn't a rattle can job, this multi-stage automotive paint though a gun. Hence the comment about Lexus.
At first I was contemplating doing rattle can, but the paint job on these cabs are Pearlescent, which is harder to do out of cans. Another option was to buy a paint gun and compressor and learn how to do the pearl, but that would have costed a bunch of money and space. And questionable whether I could have pulled off a finish as nice as this. The Auto Paint shop I went to is only 15 mins away from my house and they did an excellent job! Happy I went this route.Ah I see, I jumped ahead in the thread to see the paint job.
This is a great option! I took my Yaton cabs over to a biker who painted motorcycle parts. I figured they were both curved plastics, so the experience would transfer over. It turned out amazing. Its worth the extra money to get it done professionally.The Auto Paint shop I went to is only 15 mins away from my house and they did an excellent job! Happy I went this route.
A note on those repros, I got their 100 yen repro sticker. It was very difficult to apply because the material is very stretchy and soft. I'd imagine it'll be even more difficult with the huge side-art, as holding it from any point will cause the decal to droop and stretch.I ordered from Arcade Art Repro all the way over in the Netherlands. Waiting on Side Art, Coin insert decal, and Instruction space art.
I spent a lot of time sanding, polishing, re-sanding, polishing. But it's in good shape for now. I could probably spend a bit more time on it to get it perfect. I might do one more session on it since there are a couple small areas that could use a bit more polishing.
Thanks for the heads-up, the artwork is going to arrive today. I’ll check it out and see how different it is from other side art I’ve worked with before.A note on those repros, I got their 100 yen repro sticker. It was very difficult to apply because the material is very stretchy and soft. I'd imagine it'll be even more difficult with the huge side-art, as holding it from any point will cause the decal to droop and stretch.
Also dad gum, your restore is unreal!
I see, the best arcade monitor I have its a wells Gardner k7000 paired with a zenith tube it is just out of convergence on the corners but perfect on the center, nothing can correct the corners but it still supply the best 15khz picture I ever seen on a crt!Convergence is a funny thing. I absolutely hate to mess with it as it’s a rabbit-hole for sure. Many times, the test patterns are really the easiest way to drive yourself mad. i have a monitor that’s similar where I just can’t get that last bit to cooperate, but in game it looks fine.
Definitely black magic.
The bottom corners look like this:Well done, Is the purity ok on the lower - bottom corners of the screen?
May I take a look at your ms9 chassis? Need just a photi on primary power section and model code just to identify the revision.
Looks like the side-art is slightly lighter than the original control panel.This came out great! How does the pink compare to the original control panel pink? My repro panels are a bit darker than the original, so was curious if this art was closer or not.
Where are you getting your 18" LED BULBS from? I haven't been able to find them.Took a look at the marquee lighting.
Retrofitted a new LED bulb in replace of the power hungry florescent. I’ve replaced all my cab’s marquee bulbs with these. Cuts down on the heat quite a bit. It's especially vital for having all my cabs in one small room.
These LED bulbs only need direct AC, so you disconnect the starter and the ballast, further reducing the heat generation.
Also, after recapping and reflowing the PSU, I’m happy to see some good power numbers.
This PSU also has a solid -5v output. Definitely nice to have, especially for some of the older games.
Amazon!W
Where are you getting your 18" LED BULBS from? I haven't been able to find them.![]()
