There is no image that allows you to play 4rd Strike on a custom cart. You need a repro cart or a cart the has the SH2 converted.
The board works fine with my orginial SF new Generation CD and cartridge.
the system is jumping to the region selection screen after choosing a game and then freezes up.
I tried UniCD-CPS3_for_custom_SH2_V5 and UniCD-CPS3_for_standard_SH2_V4Black screen/freeze after region select usually indicates a mismatch between the image used for install, and the CPU being used. If it's a repro I can't imagine they used a custom CPU instead of standard., so you should be using the standard image. Best way to know for sure what is inside the cartridge is to open it up. It's pretty safe to do, not much you can really mess up by looking inside.
Do you know the filename(s) of the images you tried?
I have 2 seperate cartridges, one should be one of yours and the other one is a original New Generation one.Then that means that your cartridge still is alive and has a battery inside! It's not a repro.
That is exactly what happens when you use a CD that is from the wrong processor. If your cart is alive, you can only use original CDs. I generated a tool that allows you to create ISO images of other games and they will work with an original cartridge.
Completely at your own risk as this is 10+ years old: https://www.mediafire.com/file/ishfncinbbix91l/cps3_iso_converter_v1.0.rar/file
Then you need to use the one you got from me, but I can see that the version that you have is a version for "Custom_SH2" and you need a version for "Standard_SH2"I tried UniCD-CPS3_for_custom_SH2_V5 and UniCD-CPS3_for_standard_SH2_V4
That’s a genuine CPS-3 cartridge with a custom CPU. You can easily tell by the sticker on there with the letter “C”.![]()
This looks like the standard cpu, is that right?
so if I start the system, I just get a black screen, but if I start it holding 1P I get to the Menu, which says Security Cassette Utility Menu Ver. 3.00.Board looks original, sticker on the CPU is original. That's almost certainly a custom CPU. No battery seems to suggest it has a Darksofted BIOS (but it could also be a 2I BIOS).
Repro cartridges have a STANDARD CPU and a Darksoft BIOS.
When you start the system with that cartridge, do you see the "PUSH 1P FOR DARKSOFT MENU" prompt? If so, it's a Darksoft BIOS, and you need to use the CUSTOM CD image. You must also rewrite the SIMMs with the game data from the CUSTOM CD image.
It shouldn't be as far as I'm awareWait, is it a NoCD cart?
Repro cart will have a standard CPU that has these markings on it. Furthermore, recent repro carts don’t have Capcom printed on the PCB.
