Shingo
very anticlimactic... Let me look at what I would have to do solder wise.
very anticlimactic... Let me look at what I would have to do solder wise.I got "No SD card detected" at first when i threw all cps games folder to the root, but remember the one and only folder that is located in the SD root is "games", and within games folder you throw all cps games with there respective folder name. Hope that helps.Ok, I have everything assembled, and after sorting out a bad crimped cable issue am having an issue that has stopped me from being able to test this. I have tried 3 different SD cards from 3 different manufactures. Watched @ShootTheCore s video to get the card details, have them formatted fat32 with the individual game dirs in the root. All I am getting is the no SD card detected message. Am I doing something wrong, or missing some step? Its a dash board with a knights of the round C board. Thanks.
@MostroVeneno that was it. I had things set correctly when I first tried powering it up, but the cable issue had a blank display. I restructured the card trying to find the problem and never put it back. Things are displaying and loading now. have some other issues to work out now.I got "No SD card detected" at first when i threw all cps games folder to the root, but remember the one and only folder that is located in the SD root is "games", and within games folder you throw all cps games with there respective folder name. Hope that helps.
Great news! try to sort the other problems so you can enjoy this beast@MostroVeneno that was it. I had things set correctly when I first tried powering it up, but the cable issue had a blank display. I restructured the card trying to find the problem and never put it back. Things are displaying and loading now. have some other issues to work out now.
So the problem was that there was no card inserted, right?very anticlimactic... Let me look at what I would have to do solder wise.
I would… try a 4th. Only one of these is not a fake, can you tell which one? Only one was read as good by the multi. Garbage sd cards are everywhere and yours don’t scream ‘trustworthy’. You can sometimes tell by how quickly the card can be loaded with data. Single digit Mb/s transfer speeds probably signal a bad card. I used one that was verified good because it worked in another multi and an everdrive.
No, it was the folder structure needing Games to be the folder in root, and the individual game folders inside that one. I removed the Games folder while initial troubleshooting and moved the games folder to the root instead. The cable screwed me up at the start.So the problem was that there was no card inserted, right?
Great idea!Just tried. Mine loaded slightly different garbage, but garbage nonetheless. might just be an issue with the rom in the USA pack. I haven’t tried it from any other pack but you could give that a shot.
is it with jamma sound only?I'm still having sound issues with all the sf2 games mostly. It seems to be better if I load the game, then cycle my cabinet off/on. But even then my sound issues are abut 50/50.
Yeah, Jamma edge only. I have tried the original release pack and the USA pack. I haven't tried changing the dip switches other than the recommended setting, I figured I'd wait until someone else had the same problem and see what came out of it.is it with jamma sound only?
I had the same problem. Some games were fine but strider and ghouls n ghosts/daimakaimura would do as you are describing. Ask the other games I tried were fine.I'm having alot of sound issues as well. To name a few, the ffight, strider, sf2hfu, and sf2ce files all load and work for me, but the music will just stop and start a little later if I keep playing the game. All my dips are set to off, do we have to change them every time we switch games? Thanks
