winteriscoming
That's not a specific enough question!Nice! What are you using to create your PCBs?
There's the software side and the hardware side.
It's a pretty complex tool-chain on the software side. I'll admit I'm probably not handling everything as efficiently as possible, but I'm doing what works for me.
1. Design in Eagle and do a few different exports to EPS.
2. Import EPS files into CorelDRAW for slight vector manipulation. Eagle exports lines as lines with a given width. I need them converted to shapes.
3. Import modified EPS into Vectric Aspire to generate tool paths as gcode.
4. Open gcode in Mach3 for cutting.
Eagle apparently has the capacity to output gcode, but I haven't messed with it and really like using Aspire.
On the hardware side I've got a large 4ftx5ft cutting area CNC machine from CNCrouterparts.com. I'm milling the PCB blanks with a v-bit and drilling the holes (via CNC) with a drill bit.
Basically I'm using a giant CNC machine to mill a tiny 100mm x 70mm board.
An alternative would potentially be DIY chemical etching. I've never messed with this and don't like the idea of having drill out all of the holes manually.
