Agreed, was just posting here in case I missed anyone else with the same Control Box and issueVery much doubt it's a multi issue to be honest.
Awesome, thanks again xodaraP, you've been a great help thus far.I've got several motherboards and a stack of carts (including Pulstar) if you want to bring it down to test. Your motherboard or control box may also need a recap.
Interested to know how you go adjusting the pots assuming it has that option.
Pulstar is also known to have issues on the multi, so it could be that, not sure what the known issues are though.
Can't see any RGB pots inside the unit, and it's new. Like I said *EVERYTHING* works on this control box/supergun except for RGB output using a Neo Geo, S-Video works fine? Could it maybe be an issue with the Neo Geo motherboard perhaps or the way the encoder in the box is handling the RGB signal. Didn't @SmokeMonster have something to say about this recently?
), but I can assure that it does not work with neither the Magic Key MVS converter (the blue one, no clue about the black or green ones) nor the Daedalus converter. Incidentally, those seem to be the most decent converters available so far.
