DARKSOFT Darksoft's MultiMVS Latest Firmware, Menu and Instructions
At the Jamma connector. Maybe try also at the SP1 chip (BIOS).
It’s fine. Use fresh batteries. Turn the wheel one click to V with the solid and dash lines (not ~). Black probe on negative, red on positive. Try on a simple battery first if you want.
with the system on, put the black probe on jamma pin 1 and the red on jamma pin 3.
Ok I first mesure the battery and it was 1.36v.
Then, system on, the jamma was at 5.03v (cf pictures). After playing, system off, the battery was at 2.65v (it decreases with the time).
Meaning that I should found another MV1FS, because this model slot is stereo. What about the consolized slots like omega, analogue CMVS and other? Is there any consolized MVS slot which are known to perform well whit the Darksoft Multi MVS?
Search around the forum for ones you’re interested in, or read some threads. A lot of questions have been covered multiple times.
I use a consolized MV1C people say its not the best but it works great for me.
This guy Jeff at Chipnetics makes and sells these kits or you can but one preassembled. A CBox is another product I've seee alot of people say good things about.
https://www.tindie.com/products/chi...-neo-geo-mv1c-motherboards/?pt=ac_prod_search
Sorry, juste I am a bit disappointed to have to buy the same slot MV1FS again, for an unexplained problem, the risk is to have the same issue. With the multi AES I had an unexplained issue as well, I bought a new one and same issue. Is there other thing to test on my current MV1FS other than the sp1 (I will test soon)?
No need to be sorry. I’m just trying to let you know there’s a lot of great info on the forums already if you look?
I have had great luck using the multi with Neo Geo FZ motherboard both in a cab and on a supergun.
If you want Stereo sound though, grab the FS motherboard.
I grabbed a clean one I thought it was good but it is not ! Now I don’t know what to do. The stereo mod on the FZ, is it difficult to do ?
After more than 10 years in Japan, I over use the « sorry »
