FS Egret 2/Windy 2/NNC/Q25 (Repair refund)
Deposit placed. Apologize for the delay.
will any jvs to jamma work on a konami windy2 or I need to find their specific one?
Any will work, highly recommend @invzim’s Jammafier :)
ya I'm on the wait list for it. Do you get scanlines with his?
No, it is not an upscalee.Scanlines come from the monitor is you run 15KHz games (which 99% of Jamma games are).
The Windy should have a monitor which supports 15KHz right?
Yes, Windy 2 uses a toshiba tri-mode chassis.
ok cool I like scanlines
It is worth pointing out that a JVS-to-JAMMA solution is going to net you a few frames of lag. Most of the blame will lie on the cabinet's JVS IO board, but the JAMMAfier polls at a rate outside the JVS spec, and doing so has shown to sometimes make latency vary irregularly. Experience with a JAMMAfier with a New Net City informed the decision to abandon it, as it added around 3 frames, and get a JAMMA harness for the cabinet instead.
Not a whole lot of good info out there on Windy 2. I wonder if they all came with the JVS to Jamma I/O from the factory or if it was an accessory?
Does this depend on which JVS io is used, or jvs in general??
There isn't. Hopefully with these coming in more documentation will be done on it. I couldn't tell but I'm hoping the marquees and keys were included.
curious as I'm getting a jammafier but I got offered a Namco jvs to jamma. Which is best the Namco one or konami? I know the konami one has pinout for its stereo connection on its games.
@invzim can explain the difference and downsides of each.
They are even listed on his website ;)
https://irkenlabs.com/jammafier/video
But from personal experience (I own a Jammafier and a Namco one), the Namco one softens the image due to some caps in the video lines.
Other than that the Namco is very good :)
