what I did to see the earliest on the thread i responded just search by user name under the sales section granted that doesn't help with pms
you're mixing terminology:Thats an isolation transformer. You see them added to candy cabs alot for use with 220v in HK and China.
Not all transformers are isolating. Autotransformers have only one winding. Many cheaper step up / down converters are like this. Don't make assumptions and always double check that it is indeed isolating.I mean technically every transformer is an isolation transformer, by the very nature of the way they work.
Both works depending on the Wattage of your step down, don’t run 4 cabs of a 300w step downFor you those out there that have multiple Candy cabs and a 110 step down transformer, do you guys plug an AC strip/surge protector/or whatever you call those things into the 110 step down transformer to run all your Candy cabs? Or do you have one step down transformer for each of your cabs?
I use a couple of these, does the stepdown, surge protection, battery backup, etc. Running these for a couple of years now, never an issue.For you those out there that have multiple Candy cabs and a 110 step down transformer, do you guys plug an AC strip/surge protector/or whatever you call those things into the 110 step down transformer to run all your Candy cabs? Or do you have one step down transformer for each of your cabs?
I should probably get some of those. Never had any issues running my Blasts on 120v but better to avoid putting unnecessary strain on them if I can avoid it.https://www.amazon.com/gp/product/B000PC4JL4/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
I use 2 of these, with 2 cabs plugged into each with small 2 plug power strips.
I used to use those and they work great in conjunction with surge protectors.https://www.amazon.com/gp/product/B000PC4JL4/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
I plan on ditching the transformer and converting it to stock
They have been converted back to stock/OEM. But stock/OEM means 100v AC as that is the standard in Japan. You can plug these 100v AC cabs into US 120v AC outlets and they'll run, at least for a while. But it is recommended for the life of these cabs to step down to 100v. Lots of horror stories out there of Candy cabs dying and it has been often attributed to running them off of 120v AC. Read up on it.This is a long and winding thread but I seem to remember some discussion of possibly converting these before shipment. I guess that didn’t happen?
