@Hatsune Mike, are you parting out your E2? If you are, can you loan me the illuminated panel for a short while? I want to see if I can repro it.
I'm not parting it out, I'm going to replace the monitor.@Hatsune Mike, are you parting out your E2? If you are, can you loan me the illuminated panel for a short while? I want to see if I can repro it.
Alberto makes the best by a long shot.anyone recommend a good repro for the egret2 2p 12b? A good quality artwork on it and stuff.
https://wiki.arcadeotaku.com/w/File:Taito_Egret_II_Side_Art.pdfAlso, my buddy told me his printers can do metallic ink. Can someone point me to the art for these cabs? Hopefully, the are in vector format.
Ok, @Cereth is going to put me in touch with some people that have blank panels obtained from Taito. I'll wait for that. I can also do surgery on mine if I must.I'm not parting it out, I'm going to replace the monitor.
@8bitforlife I had no luck using the magic eraser to remove the yellow spots; did you do anything special?
Yeah brutha, what won't work. At best it is just a reference and has to be redrawn since the resolution is so low. If you have links to high res art, that would be great.
Check here, let me know if this works, havent tested it myselfYeah brutha, what won't work. At best it is just a reference and has to be redrawn since the resolution is so low. If you have links to high res art, that would be great.
^ This right here and definitely miss the chat days.Aww, thanks Gordon. You're a swell guy too. I miss our chat days.Just wanna say @300wins is the balls. Great guy.
Yeaaaaaaaaah buddy! That makes it easy since it is already vectored. These shall be printed sometime in January. My buddy tells me he needs me to give him arcade art files to print because his business's printer doesn't get enough use. If he doesn't use is printer, the print heads will go bad. And well, I don't want that to happen, so I full intend to oblige him.Check here, let me know if this works, havent tested it myselfYeah brutha, what won't work. At best it is just a reference and has to be redrawn since the resolution is so low. If you have links to high res art, that would be great.
http://vectorlib2.free.fr/Egret_II/
If you do a run of these I would love to get a couple of sets. I wish Alberto would do these.
It's a small file but it's a vector so it can be scaled without loss of quality.Yeah brutha, what won't work. At best it is just a reference and has to be redrawn since the resolution is so low. If you have links to high res art, that would be great.
