I donated mine to @Cereth and @acblunden2 to try to work on a repro. Mine was completely shattered off!Pretty sure I already know answer but no good option for e2 illumination panel still?
The last blank NOS panel purchased direct from Taito was ~$400 USD.There is a blank one on eBay for a grip
On the PB7534 chassis? Do you just need a picture and the text written on the part?Kuze can you please verify part # of q431. On heatsink near flyback. Thank you
Yes sir. or just verify k1358. Mine was broken off chassis laying loose. It test good so I hacked back in to regain HV. The heatsink clearly not original to chassis though. Just trying to see what original transisitor isOn the PB7534 chassis? Do you just need a picture and the text written on the part?Kuze can you please verify part # of q431. On heatsink near flyback. Thank you
Will do - if not tonight then definitely tomorrow.Yes sir. or just verify k1358. Mine was broken off chassis laying loose. It test good so I hacked back in to regain HV. The heatsink clearly not original to chassis though. Just trying to see what original transisitor isOn the PB7534 chassis? Do you just need a picture and the text written on the part?Kuze can you please verify part # of q431. On heatsink near flyback. Thank you
Not yet. But ordered this kit and will do it once the parts get here. arcadepartsandrepair.com says there are 4 filter caps that have to be ordered separately. They are:Has has anyone else just tried to rebuilding their chassis yet? I pulled mine today and pulled off all the capacitors and ordered a new set. Half of the caps were off-brand Chinese caps and many more leaking. Also some of the worst soldering I've ever seen on the fly back.
I ordered the same kit. I removed all of my caps and made a list but I can tell some of the Caps previously replaced aren't correct like where there are supposed to be bipolar caps I had regular capacitors there. I also had lots of really bad solder joints and probably the worst soldered in flyback I've ever seen. I can't believe my monitor even powered up with this thing.Not yet. But ordered this kit and will do it once the parts get here. arcadepartsandrepair.com says there are 4 filter caps that have to be ordered separately. They are:Has has anyone else just tried to rebuilding their chassis yet? I pulled mine today and pulled off all the capacitors and ordered a new set. Half of the caps were off-brand Chinese caps and many more leaking. Also some of the worst soldering I've ever seen on the fly back.
Going to reflow solder everywhere too. Did you buy a kit or build a list on Mouser or Digikey when you pulled yours? I am going to pull the caps and inventory them as I go. Post what I find here. Going to pull the HOT and test that too. I also have to recap the I/O board.
- 3x - 470uf 250v
- 1x - 1000uf 200v
BTW, my monitor works only barely. Here are the symptoms:
- Chirps
- As it chirps, image horizontally collapses momentarily, then rebounds
- Hence testing the HOT before resigning the issue is a bad flyback and thus the monitor is lost
- After warm up, chirping/collapsing occurs less frequently
- Vertical sides are bowed inwards
K1358 7FKuze can you please verify part # of q431. On heatsink near flyback. Thank you
