ReplicaX
It is clear now that these cabs were not in a climate controlled environment.
Before everyone rushes home with them and plugging them in:
- Understand that things get loose in shipment (neckboards, connectors, fasteners)
- Inspect all wiring, PSU connections, Chassis and neckboards. (connections, is it secured, corrosion, mold)
- Disassemble areas as needed. (Most of you want to clean these things up anyway)
- Mask and gloves dealing with mold directly, use proper disinfectants to neutralize it
- Get a few cans of dexoit or comparable contact cleaners
- Check all your voltages, if you want to be thorough disconnect the Monitor and PSU and check line voltages first. Once verified plug that PSU in and check your 12v, 5v, -5v, 3.3v depending on your cab/psu.
Checking connections, wiring, and chassis is important. Making sure everything is secure and has all fasteners is also important. Doesn't matter who its coming from, some ppl lose bolts, etc and forget about them, even hobbyists.
For the Q25 folks, you need to remove the plastic side shells and inspect everything for mold. Condensation can get trapped in there easily.
I know what its like getting a cab, trust me, after 24 yrs I still get that feeling. Take your time and hold the urge back. I did this process on brand new machines and pins out of the box and under warranty and even found issues that could have damaged things.
