Oh wait... I I guess I was confusing Tengai with another game... I was thinking of Sol Divide when I mentioned it earlier. I guess I'll need to see if my Tengai has sound issues.
You can’t really hear the problem unless you run the game on a cab directly. Using a supergun takes the amped audio back down to line level which mostly masks it. That was my experience at least.Herrs my Gunbird 2. Didnt notice any obvious audio issues, but im pretty bad at hearing such things. Video is glitching though cause OSSC dropped sync a bunch apparently.
Here is a capture from yesterday which shows the audio.
View: https://youtu.be/Rcy1CWg2m0o
Also yes. I just want to flex that 1CC.
I use mine on a Naomi converted to Jamma, so the audio goes into a "line level converter" and then goes into the Naomi amplifier. The sound is pretty terrible.You can’t really hear the problem unless you run the game on a cab directly. Using a supergun takes the amped audio back down to line level which mostly masks it. That was my experience at least.
@Nebula jumpers might be region related.
https://shmups.system11.org/viewtopic.php?f=6&t=20706&start=30
Can you take a full picture of your PCB please ?
This Dip port is bit based:
Bit 0 1 2 3
1 1 1 1 Japan, anything but 0x0f = "World"
PORT_CONFNAME( 0x0000000f, 0x0000000f, DEF_STR( Region ) )
PORT_CONFSETTING( 0x0000000f, DEF_STR( Japan ) )
PORT_CONFSETTING( 0x0000000e, DEF_STR( World ) )
I can hear the bad sound at the start of your video. If you let the opening animation play and turn up the volume, you will hear lots of unpleasant noises that vary with the video displayed.Herrs my Gunbird 2. Didnt notice any obvious audio issues, but im pretty bad at hearing such things. Video is glitching though cause OSSC dropped sync a bunch apparently.
Sounds nasty. I connected the JAMMA pins 11 and M on Gunbird 2 to the line level input of an external audio amplifier and the signal was so low I could barely hear it. Too low to even hear if the noise is present. I’ll have to stick with the nasty JAMMA audio and hope one of us finds a fix.
I wired 11 and M directly from the Gunbird 2 PCB to a 25k ohm potentiometer, then to an external amp input.11 and M are not connected on the JAMMA edge.
10 and L is the speaker but L is not guaranteed to be GND. Before connecting to an external amp you should verify that L is GND or risk damage to your equipment.
