HAPP light guns on Atomiswave?
Kujako
USA, California
I know others have gotten this to work, but not been able to find a concise guide as to what needs to be done and what hardware is needed. Anyone have any pointers?
You'll need an Atomiswave gunboard and loom between gunboard and mobo.
The happ guns plug into the gunboard, just like the original Sammy guns...same pinout.
I'll dig out my system in a few days and let you know. The only thing you need to make is the loom between mobo an gunboard.
4 or 5 wires, very easy
I just got a Sports Shooting USA cabinet in yesterday. I have 0 knowledge of the wiring configuration but this is what the connections for the Happ guns look like in my control panel. If you need better pictures please let me know.
Here some pics of my setup.
Pinout of the loom is in the last pic. I drew the connector just lik you see it in the first pic.
The numbers are the pin numbers of the connector on the gun board.
The hap gun connects to cn2 for player on and cn4 for player two. The red wire shoud go to pin 1.
OK, so think I have things wired up. But am not getting any evidence of it working. Only have Ranger Mission to work with, and it is possible that my gun IO board isn't working. Tried to go into the settings and see if there's a calibration/test mode, but I don't have a "service" button... any ideas?
Double checked the wiring loom?
My drawing of the connector is orientated like you look at the jamma connector on the mobo.
Amp-mini-U says the sports shooting manual
*edit* jst phd says nem👍😁
Wiring seems to be correct. Not sure how I can diagnose it... could be an issue with the wiring, IO board, gun board or gun.
Try flipping the gun connector when all else fails.
Tried both orientations, no luck. I did manage to get into the setup for Ranger Mission, and not even seeing the trigger being detected. Any idea what the pinout for the CN2/CN4 is? I should be able to short two pins and see it picked up as a trigger click. That'll help me determine if its the board or gun.
