Home Arcade System
Something happened to my LK button, it won’t register anymore. I thought it was the Undamned adapter but I opened that up and nothing was wrong. I put it on the first player port and it worked fine.
Anyway that was me Troubleshooting it. I was playing CvS2 against someone and in one of the matches LK stopped registering for him, first I thought it was his stick, and then I did the tests to lead up to it being not the adapters. I guess I’ll try to unplug and replug everything again.
Edit: Good news and bad news. Good news, it’s not the HAS or even the Undamned adapters. Bad news it’s Naomi related, something happened to my Naomi or the Capcom IO itself.
Have you checked your CPS2 kick harness? Perhaps it's a connection issue.
I got a Robocop PCB delivered yesterday and went to play it this morning through my HAS. It looks great on my PVM and Audio is perfect, but i can't jump. Has anyone run into this issue by chance?
Push the TEST button from HAS supergun to enter in System menu . Maybe there you can test every buttons from your stick and see if you have signal when you push them…
Here is a copy of Robocop manual : https://www.arcade-museum.com/manuals-videogames/R/robocop_manual.pdf
Guys, I've got seven HAS V4.1 units up for grabs (they were kept as backups in case some packages hadn't arrived to customers). Price is 125 EUR per unit.
Do you happen to have any CPSIO's also?
Guys can you help me with some games.
Setup is HAS + OSSC
Raiden 1, 2, DX - no picture, works fine with CRT
Sega System 32 - picture is not clear, looks just not that great compared with other games (3x boards tested, all same issue)
Pocky Rocky & Xleena Bootlegs - vertical lines, not a problem when used with CRT
Setup is HAS + OSSC
Which HAS version do you own?
