Home Arcade System
Sure, it's just holding the start button and power on the HAS (oviously) to enter that mode. I tried to do that with a dualshock3 - didn't work. Am I missing something?
EDIT: yes, when using the PS3 controller, I forgot to push two buttons together with start... oh my goodness. It's working now...
:whistling:
still not possible with wireless ones, but that's OK with the workaround....
Hey, to enter the button remapping mode in HAS you just need to press and hold start+two random buttons for 3 seconds. This can be done at any point during the game.
I bought a used HAS 2.1 that's on the way while I wait for the newer ones to come back in stock. Can someone point me to someone that sells a compatible euro scart cable I can buy to use with it?
I bought this
Here http://www.oldskoolconsoles.com/product-page/quality-rgb-euroscart-kit-separate-audio but you have to mail them in order to confirm they have this specific adapter; they sell various cables. This is UK based, so good for buying in EU. This comes as a kit, you have to assemble/solder by yourself.
Then you have this (same adapter) https://www.ebay.com/itm/EU-SCART-t...320116?hash=item2f15823e74:g:dsIAAOSwqfNXpcUe from Australia.
And, last but not least, http://etim.net.au/shop/shop.php?crn=203&rn=543&action=show_detail this should be from the original designer/builder of the adapter (always from Australia).
Regards.
Locutus73
Based on what @Locutus73 mentioned above ... @beigemore ... you can't buy one from Tim (from Australia), also you have other options to do it from 2 other places !
@RGB Please add me to your list for the HAS preorder. I would like to play CPS1 hardware and am unsure what cables would i need. I have an OSSC and a rgb cable for the nes from Tim's website and plan to order the undamned controller adapter. Is that all that's required? Thanks.
Added, thanks! You'll only need a CPS1 cable and a power supply (trusted PSU models were mentioned a number of times in this thread). The Scart RGB cable from Tim will do the trick with the OSSC.
  • hey @RGB would you please add me to the pre order list. I would love to start playing cps2 and neo geo games.
  • Like
Reactions: RGB
Thanks @RGB, I have already obtained a recommended power supply from this thread. Please also add me for the CPS1 kick harness, CPS2 kick harness, 3P4P adapter PCB, CPS2 Player 3 and Player 4 harness for the 3P4P adapterand Konami Player 3 and Player 4 harness for the 3P4P adapter if you will be making them
  • Like
Reactions: RGB
I wanted to post real quick about a problem I was having recently with my HAS. I've been using a Suzo Happ Power Pro power supply for quite awhile with mine with no issues. Recently I've been noticing a diagonal ripple on my display that has recently got worse. I replaced the Suzo Happ with a Mean Well MWP 606 and the ripple disappeared. So I can no longer recommend this power supply.
I was using the Suzo since I had trouble sourcing a Mean Well in the US when I bought my first HAS. Thankfully TwistedQuarter has us covered now. :)
Thinking this might've also been a problem with my SCART cable, I also picked up an extra shielded NESRGB cable from Retro-Access and wanted to report this also works great. :thumbsup:
  • Like
Reactions: RGB
Install shots (and my one cord HD15+3.5mm solution)...
For the OSSC to lock the the F3 via HD15 adapter, the HAS must be set to output Buffered TTL Sync.
Open/remove the jumper at location #17 (TTL) and move the jumper at location #18 to center (buffered).
The OSSC must have both its Pre/Post Coast set to 4, and be in mode AV3: RGBS (the first/default mode is AV3: RGBHV).
@jassin000
Question for you. I have the OSSC and plan on using these settings to hook up the F3 board I have, but I would also like to leave all the settings alone for CPS1/CPS2/Sega 16 (and maybe other boards). Can I use these buffered settings or do I have to change everything back for the other boards? Will leaving these settings on damage anything (boards or OSSC) to test?
