Home Arcade System
Yes, it's possible, HAS offers six outputs per player via the JAMMA connector (so this includes button 5/MVS "select"). PM me your email address and I'll send you the instruction manual.
Hi RGB, I replied to you with what I need and which adapters by PM.
Hello RGB, I sent you a PM about a supergun order. But I'm not sure if that's how it works here, or should I post here?
Thank you, it's always better to send a PM. I'll answer to all PMs today.
Hi,
newbie here, I was searchin' for infos about getting a Supergun and I landed here after SmokeMonster's interview in last RetroRGB podcast.
I'd like to be put in list to buy HAS with all options, what should I do besides posting here?
Thanks.
EDIT: sent PM to RGB.
Anyone know the best way to get the 8 PIN DIN video output the HAS outpus onto a CRT with RCA/component?
And likewise the cheapest way?
Thank you!
Got mine today and I have to say this thing is quite impressive and thanks so much! My only suggestion for future orders is asking the person if they use any sort of Jamma extension cable. The CPS2 kick harness for mine is too short to reach the HAS as I use an extension cable but it's not a huge issue. Turned out I had spare plugs to crimp my own longer harness which fixed that. The main reason I use an extension cable is I don't like having something hang off the Jamma edge and some boards have it set relatively high in comparison to where the board would sit once mounted.
Edit: that said I do have a question though - is it possible to wire up the 3p/4p adapter with the VGA port or do the two boards rub up against one-another (while retaining the plexi)? This thing is so cute once all put together that I kind of regret not getting the adapter and am considering ordering one with some harnesses (hopefully longer though! ;) )
Reactions: RGB
Thank you!
RGB offers a component, S-Video output board that plugs into the HAS
he ran out and won't restock soon, so I'm not sure what route to go to getting video out
Thank you!
It's very roundabout but this is how I get component on my CRT setup (mostly because I ran scart/xrgb-mini previous for my consoles so it dropped in)
I use this adapter to convert video/audio to scart from the HAS https://www.ebay.com/itm/EU-SCART-t...-xrgb-nintendo-sega-neogeo-retro/202224320116
Along with this http://www.ani-av.com/shop/product_info.php?products_id=220 to convert to component video.. I actually just run the audio from the HAS directly into this device but I could run it through the scart connector if I really wanted to.
This setup has worked flawless with all of my consoles and arcade boards. The Shinybow converter also has a LM1881 sync cleaning circuit so it works well for things like Genesis that use composite video for sync. An added bonus with this setup is it'll work with any euro scart system so it isn't dedicated to a single device.
I know what you mean with the JAMMA extension, I really wish I could offer them, but they involve too much work.
As for the HD15 adapter, it's just stacked on top of the 3P4P adapter. The HAS becomes quite tall with two modules attached (modules and plexi glass cases are separated with 15mm stand-offs), so the alternative here is to use the 8pin mini DIN to HD15 adapter instead.
is there anyway to wire a button for on off? My has works great and everything but was surprised there was no way to turn it off besides unpluging it
True, but you can easily solve it by putting one of these inbetween:
Would need a sizeable switch to incorporate it into the PCB. Lots of voltages to deal with and it would need to be able to withstand up to 15A. Not as trivial as it sounds.
Reactions: RGB
May I suggest this?
http://sonoff.itead.cc/en/products/residential/s20-socket
With third party open source firmwares (like this https://github.com/arendst/Sonoff-Tasmota ) it can be integrated in any domotic environment.
Hey Siri: turn on the Neo Geo!
Regards.
Locutus73
