The 3.5mm jack on the HAS would be audio output from (mono) JAMMA harness.The 3.5mm jack is just output right?
Same for a stereo modded MVS.The 3.5mm jack on the HAS would be audio output from (mono) JAMMA harness.For something like CPS2 you would want a RCA to 3.5mm stereo cable, and use it directly connecting the CPS2 audio to the OSSC.The 3.5mm jack is just output right?
Could depend on the mod, so I was intentionally silent on this point.Same for a stereo modded MVS.
THX. Sound from scart to HDMI direct. No need other connection.So if you have a OSSC that can encode audio, you should only need the 8pin mini-din to SCART cable for connecting the HAS to the OSSC.However if that "special" OSSC demands audio be supplied via 3.5mm audio input only (and not over SCART head)...I Have a special version, a 1.5 with digital audio chip add on via HDMI. uptodate.
You'll then need to add a 3.5mm to 3.5mm audio cable to the mix, it will connect directly to the HAS and OSSC in addition to the SCART cable.
I have the same OSSC - 1.5 with the HDMI digital audio mod. I use the Retro Access NES SCART cable with 8 pin DIN and stereo audio 3.5 plug with my HAS and it works great.So if you have a OSSC that can encode audio, you should only need the 8pin mini-din to SCART cable for connecting the HAS to the OSSC.However if that "special" OSSC demands audio be supplied via 3.5mm audio input only (and not over SCART head)...I Have a special version, a 1.5 with digital audio chip add on via HDMI. uptodate.
You’re right, so let me rephrase my sentence: same for a line-out level stereo modded MVS.Could depend on the mod, so I was intentionally silent on this point.I run my Neo-Geo in mono via JAMMA edge only so meh... CPS2/3 are RCA stereo all the way!Same for a stereo modded MVS.![]()
I might be wrong, but I recall reading that you must feed audio through SCART (if you use AV1 SCART input); the 3.5mm input is for other inputs (VGA and component).You don't need to feed the OSSC 1.6 audio over SCART... So I doubt you need to do that with the 1.5+audio.
You see it has a 3.5mm input, so yea bypass the HAS but no need to reinsert audio into a SCART chain. Just take it directly from the arcade PCB.
Interesting, I have a 1.5 pure (no audio add-on) and a 1.6... I just assumed they were the same in this respect.if we’re talking about OSSC 1.5 or earlier, while I’m right (you must use SCART for audio) with 1.6.
Ok, so who is making these? Need like 4Its pretty straight forward.
Get the blue cable and label the wires 1A to 6A. Cut the CPS2 side plug off.
For the white wires Label the CPS2 end as 1B to 6B and the HAS end 1C to 6C
The switch is wired like this picture.
Im lazy and only labelled one side but you get the idea.
When cutting the white cable only cut 1 wire at a time, so the cable lengths are staggered.
This way you end up with a nice tight bunch of wires that have an unaltered length compared to the ones we didn't cut.
Ill let you guys figure out how to get the heatshrink over it![]()
@RGBany chance for update with save more map button (For exemple: 1) mvs, 2) cps 3) shinobi)
Can you explain what you mean ?any chance for update with save more map button (For exemple: 1) mvs, 2) cps 3) shinobi)
I think he means saving different button mapping presets, with an easy way to toggle between them, without having to redo the mapping from scratch.Can you explain what you mean ?any chance for update with save more map button (For exemple: 1) mvs, 2) cps 3) shinobi)
The HAS already has remapping built in.
It will work with MVS out of the box because 1 slot MVS motherboards are standard JAMMA
In addition if you use Undamned's USB decoders they can also remap![]()
It would also be awesome if it cooked me breakfast in the morning... But that's not going to happen either.Map one time for all system and jump on right map when you connect a cystem.
4 5 61 2 31 2 34 5 62 3 41 5 6THXHow many mappings would really be necessary?
For a 6 button joystick / controller I could see the practicality of 2 presets:
Preset 1:
4 5 6
1 2 3
Preset 2:
1 2 3
4 5 6
Perhaps even:
2 3 4
1 5 6
Remapping mode -> Hold down 3 buttons and Start, Select Mode 1, 2 or 3?
I guess user configurable saves would be a whole other issue though...
