DARKSOFT How to convert a Xbox PCB to repair Chihiro
I would like to repair my Chihiro, do I have to have MCPX2 in both cases or is MCPX3 fine? I didn't understand this, thanks
If you have mcpx2 just flash it add ram and good to go.
Though these are extremely uncommon.
Mcpx3 requires more and the cracked bios but easily obtained.
Qualcuno può aiutarmi per una conversione Xbox con chip mcxp3? Grazie, non ho capito come si fa
Hai tutti i file necessari nel primo post. Sono per MCPX X3. Leggi di nuovo il primo post.
Just thought I would add another successful conversion to the list. Thanks to all involved in getting this working.
There's nothing special with 1.0's, you just need the USB riser -- the MCP requires it.
The v1.0 is the only one to mount this small additional PCB of the inputs.
It must be absolutely kept on the chihiro conversion, otherwise you will have the error 02.
This small pcb mounts an oscillator crystal and other logic.
