Yup I am using the ones that came with it as there was no others to use or mentioned in the guide. I can meassure them tomorrow but just assuming they will be the same. It might also just be the cable that I got that bends a bit differently than your cable or something? It's very rigid and sturdy so it's hard to kind of make it go anywhere else.@Dloop, are you using the stock spacers that came with the DE10? I just measured mine at 10mm.
I should try unplugging it and bending it a bit harder like you show. Thank you for the tipJust pulled out a new one to be sure (they're all from the same manufacturer/batch). Bu sure to plug connect it to the DE10 last, after mounting it on the PCB etc. I 100% I don't have magic touch, but maybe I should put a note about it on the hardware install page. I gave the cable a bend upwards on the edge of the DE10 before connecting it.
Plug the micro usb end last to the DE10 nano and make it naturally rests like in the pics.I should try unplugging it and bending it a bit harder like you show. Thank you for the tip
That’s what I did. I will try bending it, and look for another cord more like in your picturesPlug the micro usb end last to the DE10 nano and make it naturally rests like in the pics.
Can't do full-on MiSTer (software) support, but there shouldn't be anything special to configure to get controls working, especially when in keyboard mode and using e.g. jotego cores.Got mine yesterday and I have to say I am extremely impressed - it truly is an awesome bit of kit. I tested it in my Aero Table with my default MiSTer build that I have been using for months now and it worked flawlessly - I then managed to mess up my SD card and had to rebuild MiSTer from scratch and I can no longer get to the controls to work even though they register on the expander. I presume I need to configure the controls again in the MiSTer setup - does anyone know if there is a quick way to achieve this maybe an ini setting to reset it to be compatible with the expander.
Naive question - do you have any idea, simply theory crafting) on how your product will differ from the MiSTercade option that was available? I will be looking to get one or the other eventually and don't exactly see Youtube videos comparing the two. Thanks!Can't do full-on MiSTer (software) support, but there shouldn't be anything special to configure to get controls working, especially when in keyboard mode and using e.g. jotego cores.
If you were in keyboard mode and tried to define joystick buttons, I would just remove the config file and try again - details why this is a bad idea on the page about gamepad mode.
https://irkenlabs.com/jamma-expander/operation
https://irkenlabs.com/jamma-expander/operation-gamepad
got it off amazon, startech oneWhich right angle USB cable are you using. I'm struggling to find a micro usb right angle, with a female USB on the other end, in that length. Or did you make a custom cable?
Firmware updates
