Mackie
Note that I’m not using the ram (as I still wait for it to be delivered), but I would have expected to at least see the menu.
Or just fire up a jotego core like any CPS1/CPS2 title or DoDonPachi from nullobjectIt worked. Thanks.
Now I need to look at setting the controls.
There's an easy fix to make them work though.goto jotego core and enable beta updates. CPS2 is still considered beta, but it's public beta. There are other beta cores you will get that you will see but when you try to play them they will give you an overlay on the screen saying you need to be supporter and they won't work
WIth the current firmware, jamma edge needs power first, which then powers the DE10, which ultimately powers the expander.@invzim Looks like the jamma edge needs to be powered on before the usb powered hub. Is there a way to change the behavior (disable) via firmware update / menu option or something? I'm assuming this is part of the voltage guard thing?
), but can probably make it configurable by editing the .ini file you get when you save the config on the Expander.WIth the current firmware, jamma edge needs power first, which then powers the DE10, which ultimately powers the expander.
I don't guard the voltages, it's only warnings/notifications. I'm leaning towards discouraging 'creative setups' (as I don't want the support), but can probably make it configurable by editing the .ini file you get when you save the config on the Expander.
I'm making a few smalls changes for an updated firmware, so all input is welcome and appreciated.
What's the use-case?
use-case = powered usb-hub has to be turned on manually after powering on the cab, would be nice to have the cab and usb-hub on the same power switch. Not a big deal. Currently I'm powering on the cab, waiting a few seconds then powering on the usb-hub. Routed a powered usb-hub through the rear of the cab, I have external usb ports for wifi updates, keyboard, and gamepad. It's very practical and easy to manage the Mister this way, never have to open the cab.Then you just won't get the vertical games. Plenty of others to enjoy.Rotating the mon just isn't of interest to me, especially if I'm gonna be swapping cores randomly.
