Yup, sensors are passive.Cool
@djsheep was just thinking, when you wanna play a gungame with 2 players, am I right in thinking 1 set of sensors and 2 guns is sufficient in case of the Guncon3?
Is there a wiring diagram for this use case? How would I connect the 3 USB cables (2 guns, 1 sensor)?
Awesome, thanks for the insight. I would like your post if only i knew how to do it.Like with the Wii sensor bar, the GunCon3 sensors just need power. There's no data (like ~%90 sure). That being said, most people seem to just use a USB hub.
Okay, that might be it then. I have plenty of X360 controllers, but none of them are wired. I'll have to get one, thnx. Still wonder why PS3/PS4 won't work though as they don't come in wired versions...I use a wired XB360 controller and it just works. I don't have to do anything special.
This is my experience until now as well. On my Naomi it works 1 try out of 20 maybe. Tried it at @PascalP the other day and it worked every time for him. Very annoying to say the least. Has this issue been reported yet?For those of you who have problems with Naomi, I'll tell you about my experience:
It works for me on some bases and not on others, I don't know why, if it's a problem with the filter board or not.
what I recommend is that if you have other Naomi bases, test it with others
