i would also like to see that full setup as well
I've never actually seen a complete TCR system though I have come across one or two people who have part of one still in their E29
My neon replacement… which are not working
Yeah rip all that cheap stuff out.
Sunlight makes a excellent high quality LED fixture that mimics the same shape and color temp as the florescent assembly in our machines. I am not a fan of the heat and plastic damaging qualities the OG florescent tubes give off so I took mine out and put it into storage, capped off the original wiring without damaging it. All the orginal cabling runs up the right chrome arm along with the speaker cabling. Between those cables that tube is full so I ran new electrical wiring down the left side tube that runs the LED fixture independently of the main PSU of the cab. This way I can run the marquee lights even when the machine is off and 24/7 basically without worry and only 9 watts. The shape of the this LED fixture brings the light source down in a way that shines that light correctly onto the green marquee in order for it to light up properly as well.
While i was in there I replaced the speakers as well with correct drop ins, for the price of the speakers if it was worth to get it all new, I didn't want to have to worry with reopening that part up later.
got a link?!Sunlight LED fixture
yeah ... thanks to your picture I see exactly what I needthe original AC power panel would be very simple to recreate from scratch, it's basically just a block of MDF with some common off-the-shelf parts.
got a link?!
Speakers : oval 5x3, shielded. Good ones are not so easy to find.... thanks for creating a need!
Yep, here is the link for the 12 inch version
https://www.amazon.com/gp/product/B08ZBL8KVD/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
They have a 22 inch version that works perfectly in most other candy cabs, I have replaced all my cabs with these for the same effect with independent marquee lighting.
The speakers seem to come and go, the link i had for them is gone nowbut search up: 3 X 5" FULL RANGE REPLACEMENT SPEAKER BUTTON MAGNET 5 WATTS 8 OHMS. The size of the magnets becomes an fitting issue more so in the speakers that are in the pods down below once you get to them.
That's not warm, that's practically pumpkin!it's a warm light all right:
Nice crimping man!Crimp crimp crimp crimp …
Turn on. Blue switch bye bye! Hello new old switch!
And more crimp crimp crimp left
Thanks @twistedsymphony for that colored schema!![]()
Nice crimping man!
Do you you mind sharing a photo of the inside grooves of your crimping tool?
A weird request but it will instill confidence when I have to crimp my CP on the Goldfish catcher.
Ah Nice, I like how you moved the remote board down to there. The stock position was a bad choice, not sure what they were thinking with that.note to idiot self: make sure the buttons you're using are normally open and not normally closed
anyway ... remixed and reprinted and moved everything with new buttons...with reinforcements at the bottom (don't ask).
Of course not moving the top hole enough to make that remote board straight. OH WELL.
