1.- YesIs this board a kind of merge of a JVS I/O and a S-JIHP ?
If yes, where do you plug analog controller in ?
Would it be possible to plug a 'standard PC' wheel ?
2.- IDC 26 Pin connector
3.- Yes if you adapt the wheel to the 26 pin connector
)I know a few people in this same boat.(I never managed to plug a wheel on my S-JIHP )
What else would the pedals have in them other than pots?You need one with at least pots for gas and brake.
Plug, no. Mod, possibly. It has to have pots for gas, brake and the steering wheel. The first two more than likely use pots, but steering wheels can have encoders. Encoder based wheels won't work.Would it be possible to plug a 'standard PC' wheel ?
And the steering wheel as well like @nem just said. I've never opened my Logitech G29 but I bet it wouldn't be compatible.What else would the pedals have in them other than pots?You need one with at least pots for gas and brake.
they did its called jammafierThats pretty cool. Unfortunatly for me i'm still a edge connector guy but hopefully one day someone will build a new Jvs to jamma adaptor, i'm sick of those sega/capcom stuff, they are getting too old
No, that's the other way aroundthey did its called jammafierThats pretty cool. Unfortunatly for me i'm still a edge connector guy but hopefully one day someone will build a new Jvs to jamma adaptor, i'm sick of those sega/capcom stuff, they are getting too old
The Jammafier is a master(game) talking to slaves (io boards) using JVS.oh sorry. I use it as a jvs to jamma in my windy i didnt think about that the windy2 has an io already.No, that's the other way aroundthey did its called jammafierThats pretty cool. Unfortunatly for me i'm still a edge connector guy but hopefully one day someone will build a new Jvs to jamma adaptor, i'm sick of those sega/capcom stuff, they are getting too oldThe Jammafier is a master(game) talking to slaves (io boards) using JVS.
Awesome!Exactrly that. Thanks @nemWhere this IO excels is driving games. Unlike stick and button games which more or less follow a standard, the mappings for analog and digital inputs in driving games are all over the place. So in one game 1P SW1 could be shifter up, in some other game it could be view change. Brake could be acceleration and vice versa. If you wanted a to have a multi driving cab, you would need to swap harnesses all the time. With the Multi JVS you just press a button on the IO to swap to a different mapping and off you go.
