antonioad14(TWON)
Lmao, clearly. Do you know what the dip switches on the back of the system do? Honestly feels like my only hope at this point.You should work in QA![]()
Yes.The clock battery on the bottom board is the one that needs to get switched out right?
You can tell they designed these systems with the intention the games won't be switched out.Yes.
You would need to change it if you load a game, set the options, turn off, and then load then SAME game and the options aren't set anymore.
If you switch games, you normally have to reset options.
Haven't experienced any crashing yet, but have been noticing some micro stutters and longer loadtimes then normal, also that audio issue seems to just happen randomly, on my first test it was after my second race, and on the second boot I was able to get much more races and play for around an hour in before it started doing the weird distorted audio thing again.I think I had this issue on one of my systems - but after the slowdown, it crashed. I ended up taking the CPU off, cleaning it - putting down new thermal paste and making sure everything was put back together.
