NAOMI 2/Chihiro/Triforce Card Reader Emulator (Initial D3/WMMT/Mario Kart/F-ZERO AX)
I've got my first test print using real game data, doesn't look too bad, just need get some higher res scans as this one is ripped from a Japanese auction site with the original print data photoshopped out!
That would be brilliant, thanks very much, I'd be grateful for any that you have, the aim is to get a selection so a random card is offered when purchasing in the game.
I'm missing some in the scans but I have all the cards except the Jp exclusive one that came from the Gamecube. Potato quality at its finest
Wow! I honestly didn't realise there were so many! many thanks for scanning them in, it's great to see them all together like that - unfortunately ... I need them at a higher res :unsure: - the other cards I have are all around 600x1000 pixels each to capture all of the card detail and make the icons clear when printing them, I know it's asking a lot but would you be able to rescan at around 300dpi for me please? if that's not possible, no problem, I now have a list of all the ones I need to find!
96dpi according to Windows, the files attached here are only 200KB each, did they get resized when attached?
Probably. There is a hard limit i believe to post pics. Pm me an email address and I'll send it when I have a chance
Got them, they are perfect! thanks so much again for scanning those in for me, the F-Zero code is all done now, I'll release it along with Mario Kart which I'll start this week
For F-Zero AX, the serial connector pins are 4,5 (rx,tx) and 8, gnd - on JP3 right?
Either way I have rx and tx I get a card error upon bootup.
(I have CTS and RTS connected to each other).
Matt
These are the ones I have in my notes:
F-Zero - J3 on Triforce
Pin 3 [or 8] (GND) - Pin 5 (GND)
Pin 4 (TXD) - Pin 2 (RXD)
Pin 5 (RXD) - Pin 3 (TXD)
Pin 6 (RTS) - Pin 8 (CTS)
Pin 7 (CTS) - Pin 7 (RTS)
Naomi - CN8
Pin 1: RXD to Pin 3: TXD
Pin 2: TXD to Pin 2: RXD
Pin 3: GND to Pin 5: GND
Pin 4: RTS to Pin 8: CTS (This may actually not be needed)
Pin 5: CTS to Pin 7: RTS
Namco - J3 on Triforce, CN5 on Chihiro
Naomi - CN8
Ahhh ok - so Fzero needs CTS and RTS - I will get that hooked up and give it a shot. Thank you!
Matt
