192.168.193.xxxWhat is your home wifi ip? I had to change the wire ip range as it was the same range as my home wifi. After that it work
My issue was my home wifi was in the 10.0.0.xxx range which conflicted with the wired range. Did you try logging in with the pi ip once you switch over to local wifi instead of http:/netbooter.local? I have to do that now as the above no longer work for me. I had to go into my router and give the pi a static ip so it won't change on me.192.168.193.xxx
The pi wasn't accessible once I added the wifi name and password. I have two separate sd cards with the latest and previous versions, both with the same wifi info. the previous version works still soo not sure what's the issue.My issue was my home wifi was in the 10.0.0.xxx range which conflicted with the wired range. Did you try logging in with the pi ip once you switch over to local wifi instead of http:/netbooter.local? I have to do that now as the above no longer work for me. I had to go into my router and give the pi a static ip so it won't change on me.
I always assign static ips to my devices when I can. Im gonna try doing these setups this weekend and see how it goes.My issue was my home wifi was in the 10.0.0.xxx range which conflicted with the wired range. Did you try logging in with the pi ip once you switch over to local wifi instead of http:/netbooter.local? I have to do that now as the above no longer work for me. I had to go into my router and give the pi a static ip so it won't change on me.
How do I set th pi IP to 10.0.0.1???You don't have to reburn the image. Next time if the wifi/network setting get mess up just create a reset.txt in the root of the sd and boot it up. I don't recall if you have to cycle the naomi or not but once you boot it again the network setting should return to default. The pi wired ip should be 10.0.0.1 and the netdimm should be +1 so 10.0.0.2. I am using 192.168.1.1 for my pi and 192.168.1.2 for 1st netdimm
Why would you use a Pi4 for something like this? A Pi3B should do fine I'd say? Or am I missing something here?I just bought a Pi4 2gb, which I think should be fine for this, as I'm not trying to play games on it. On e-bay for like $120 which is still highway robbery as those were $40-60 not too long ago.. but what can you do...
Yes, that, and also for me Pi4's are/were cheaper than Pi3B+ which is also odd, but the way it is, right now... :/From what I recall, Pi4 on a WiPi setup allows for using the OpenJVS Hat along with a bluetooth dongle. Don't think you can use both on a Pi3 because of a conflict of ports or something.
Yeah I've been ripping appart some of my older Retro-Pie builds as I now have a MiSter and don't see a huge upside for those right now, I typically pull the SD card, order another, and keep the old one filed away, if prices return, I'll just plug that old one back in...Dang and here I am glad I didn't toss my ancient 2011 pi 1and super grateful I was using the pi3B back in 2016 for a mame bartop build lol
