Pretty sure Paradise Arcade takes PayPal. I assume DS is going to use them, or another distributor, and not sell them himself. Assuming you're in the usa
Thanks guys!I don't think it matters what Neo Geo motherboard you use. You can use any Neo Geo cart with any Neo Geo motherboard, and the multicart will work the same way.
Nope - I'm a Brit in the Netherlands. My company's IP is routed through Austria for some bizarre reason - hence why credit card companies get confused and block the transaction more often than not. Paypal really don't seem to care which is great!Pretty sure Paradise Arcade takes PayPal. I assume DS is going to use them, or another distributor, and not sell them himself. Assuming you're in the usa
for sure in Europe saveyourgames will be a distributor, maybe there would be a 2nd in Europe.saveyourgames.it is the place to be for us Europeans![]()
At least if the MVS multi will have the same distributor as the CPS2 multi that is...
Yep, plus one for sure on this!If you're interested in second US distributor, you might consider https://www.multiboards.us, new sister site to https://www.highscoresaves.com. Joe is good people for sure.
Ms2 has slowdowns because of poorly optimized code.I've read with keen interest about overclocking the NeoGeo to help with slowdown. One of the videos I've seen shows that Metal Slug 2 can be improved but implies there is still some slowdown that can't be reduced with a different clock crystal because of the speed of memory used in the cartridge.
If this claim is true - will carts like Darksoft's be able to help with these sorts of supposed speed issues, and could the speed of the ram be overclocked through the software that controls the cart?
Bank switching allowed SNK to surpass the original 330 spec. So 'Giga Power' is essentially marketing for larger games.What is the difference between Max 330 Mega Pro-Gear Spec and Giga Power Pro-Gear Spec ?
And AFAIK, unofficial games (Razion) have made it up to 1.5Giga power (1536Mb) so the neogeo still has potential for great titlesBank switching allowed SNK to surpass the original 330 spec. So 'Giga Power' is essentially marketing for larger games.What is the difference between Max 330 Mega Pro-Gear Spec and Giga Power Pro-Gear Spec ?
They changed the eyecatcher to announce that they have extended the ROM board specs. That is simply a market slogan, like SEGA's "blast processing".What is the difference between Max 330 Mega Pro-Gear Spec and Giga Power Pro-Gear Spec ?
Umm... could you be more specific?They changed the eyecatcher to announce that they have extended the ROM board specs. That is simply a market slogan, like SEGA's "blast processing".The maximum theoretical ROM a Neo Geo cartridge can do without external banking is:What is the difference between Max 330 Mega Pro-Gear Spec and Giga Power Pro-Gear Spec ?
CHA512Y: 64Megabytes(512 megabits)CHR + 128KB FIX (1 megabit) + 128KB M1 (1 megabit) = 514Megabits
PROGBK1: 16 Megabytes (128 megabits)V + 8MB(64 megabits) P1+P2
514 + 192 = 706 (This is exactly the megs count for SVC Chaos)
The biggest game is KOF2003 with a meg count of 716Megabits. It has additional banking on FIX (fixed layer font) and M1 (music CPU ROM) so it can have more tiles for screen fix and more music data.
Theoretically it could hold much more than that much (706 megabits) as every bit added to the banking doubles the amount of addressable memory. But really the Neo Geo stopped there, with adding extra FIX and M1 banking.
Extended M1 and a new FIX banking were implemented in the CHAFIO board (CMC 042/050 chips), which KOF2003 and others of the later gamesBank switching allowed SNK to surpass the original 330 spec. So 'Giga Power' is essentially marketing for larger games.What is the difference between Max 330 Mega Pro-Gear Spec and Giga Power Pro-Gear Spec ?
