Pre-built SD for 1.0.0-RC1 for use with SD2PSX/PSXMemcardGen2
extraweb1
USA
This is pre-built sd card structure for 1.0.0-RC1 for SD2PS/PSXMemcardGen2 and will display the dongle name and version on the screen for easy identification.
- Instructions
_______________________________________
1. Flash sd2psxtd-1.0.0-RC1.
2. Drag and drop [MemoryCards] folder from the drag and drop package to a MicroSD card.
3. Put MicroSD into a SD2PS/PSXMemcardGen2.
4. Deploy CIV in the menu under PS2.
5. Change the variant to arcade in the menu under PS2.
6. Use as you would like.
!!!! Remember to check the compatibility and I/O requirements of the game you are trying to boot. !!!!
!!!! All dongles are pre-signed/bound to SD2PSX / PSXMemcardGen2 !!!!
!!!! Remember SD2PSX is not a micro SD card reader for PC so when deploying the civ.bin do not drag and drop the civ.bin where you drag and drop the firmware!!!!
- How to use
1 . Power externally
2. Turn autoboot off in the PS2 settings menu
3. select the dongle you want to boot
3. Remove external power
4. Put it in your namco and Boot it like a real dongle
This should be possible because of "https://www.arcade-projects.com/thr...th-arcade-magicgate-support.32371/post-451920"
!!! I have a report of this not working through a third party multitap hooked to 256, so this warning will stay here until someone who has a PSXMemcardGen2 that is sanded down and doesn't use a multi-tap on a 256 confirms it working or broken!!!
- Link to sd2psXtd 1.0.0-beta12
https://github.com/sd2psXtd/firmware/releases/download/1.0.0-beta12/sd2psx.uf2
- Link to pre-built MicroSD drag and drop package.
https://archive.org/download/sd-2-psx-psxmemcardgen-2-pre-built-micros-sd.-7z/SD2PSX - PSXMEMCARDGen2 - Pre-built MicrosSD.7z
NOW INCLUDES PATCHED GAMES ON CHANNEL 12 CARDS 2-4
- Source for original dumps
https://archive.org/details/system2x6
TO USE A REAL DONGLE
1. download https://archive.org/download/bound-sd-2-psx-by-name.-7z/UnBound.7z
2.Extract the files of the dongle you want using isobuster to a flash drive
3. Load the special version of wle attached
4. Copy extracted dongle files to the dongle of your choice
5. Use donglebinder atttached to bind boot.bin to the dongle or device of you choice
6. Use it
Thanks this is awesome, it worked fine on 256 with a shaved sd2psx. I'll need to make a cheat sheet of what games are on what card/channel. Unfortunately I've discovered I got no sound on my 256 I need to figure out.
Hi !:)
For me too it's functional, everything is fine. :thumbup:
I did the tutorial step by step with my friend mr magoo's on the phone :whistling: :thumbsup:
Hi! :)
You could include
Tekken 4 all versions with Attract Mode Music Mod ?
https://www.arcade-projects.com/threads/tekken-4-attract-mode-music-mod.29422/
All versions of Tekken 4 Attract Mode Music Mod with the additional widescreen patch ?
https://www.arcade-projects.com/threads/tekken-4-widescreen-patch.31841/
there is also one versions of Ridge Racer V Force Feedback Patch all version ?
https://www.arcade-projects.com/threads/ridge-racer-v-force-feedback-patch.27412/
Thank You Very Much :thumbup :
Now that you bring widescreen patch to the chat.
Since a loooong time ago I made a version of cheatdeviceps2 that works on arcade units.
Might work as a decent testing app when making widescreen cheat, saving you the hassle of modifying dongle contents over and over and over
Hi! :)
You could include
Sure I will add them soon
Hi! :)
You could include
Here is the patched games pre bound.
https://archive.org/download/bound-sd-2-psx-by-name.-7z/Patched games.7z
1. Choose the folder that corresponds to the device you will use it on.
2. Rename one of the cards to whatever card you want and put it in its corresponding folder on the sd card
`` "e.g. MemoryCards/COH/Card1/Card1-1.mcd"``
3. Use it
If I remember correctly, Cheat Device froze on second boot on the 246.
As for testing,it depends if you can target other files besides the main game executable. For example the Tekken 4 GAME file contains most if not all of the game's code and that's where you would apply patches.
I personally built a version of Play! with the debugger attached and it made the entire process more simple but having an additional Cheat homebrew for the units is a good alternative for sure!
Yes, I'm aware of that and found the issue.
For some reason, the normal method to run KELF files (boot.bin in this case) is jumping to OSDSYS and triggering an error regardless of what I do. It needs investigation
can anyone help me?
Follow the steps above
When I get here it says it can't find the civ.bin for the deploy?
and another, do I put the tekken 4 iso in the card 1 directory without renaming? the name of the game?
put civ.bin on the sdcard :)
You don't. This feature is not available for arcade systems, yet. - For namco it is only used to deploy security keys. - Launching ISOs is only avaiable for PS2 and only with a specific OPL version
I have a Namco System 246
so I can't use it?
Are you saying that if I had a PS2 I could use Tekken 4 in arcade mode?
