Hello,
By any chance, does anybody has at hand the cap list for a nanao ms-2932. I don't want to buy a premade kit online.
Thanks!
I have one here.
Can make it this week end if you are not hurry
Hello,
Thanks!
I can surely wait!!!I have one here.
Location | Capacitance | Voltage | Temp | Width | Height | Lead Spacing | OEM Brand (All seem to be crap brands) |
C7 | 330uf | 200 | 85 | 22 | 30 | TK (Toshin Kogyo) | |
C6 | 330uf | 200 | 85 | 22 | 30 | TK (Toshin Kogyo) | |
C5 | 330uf | 200 | 85 | 22 | 30 | TK (Toshin Kogyo) | |
C301 | 1uf | 50 | 105 | 5 | 11 | CS (12 Kuang Jin) | |
C201 | 1uf | 50 | 105 | 5 | 11 | CS (12 Kuang Jin) | |
C101 | 1uf | 50 | 105 | 5 | 11 | CS (12 Kuang Jin) | |
C306 | 68uf | 63 | 105 | 8 | 11 | CS (12 Kuang Jin) | |
C206 | 68uf | 63 | 105 | 8 | 11 | CS (12 Kuang Jin) | |
C106 | 68uf | 63 | 105 | 8 | 11 | CS (12 Kuang Jin) | |
C305 | 47uf | 50 | 105 | 6 | 11 | CS (12 Kuang Jin) | |
C205 | 47uf | 50 | 105 | 6 | 11 | CS (12 Kuang Jin) | |
C105 | 47uf | 50 | 105 | 6 | 11 | CS (12 Kuang Jin) | |
C115 | 33uf | 50 | 105 | 6 | 11 | CS (12 Kuang Jin) | |
C311 | 2200uf | 25 | 105 | 13 | 26 | CS (12 Kuang Jin) | |
C211 | 3300uf | 10 | 105 | 13 | 26 | CS (12 Kuang Jin) | |
C213 | 3300uf | 10 | 105 | 13 | 26 | CS (12 Kuang Jin) | |
C111 | 3300uf | 16 | 105 | 13 | 30 | Asia'X | |
C113 | 3300uf | 16 | 105 | 13 | 30 | Asia'X | |
C112 | 1000uf | 16 | 105 | 10 | 20 | CS (12 Kuang Jin) | |
C214 | 22uf | 50 | 105 | 5 | 11 | CS (12 Kuang Jin) | |
C114 | 22uf | 50 | 105 | 5 | 11 | CS (12 Kuang Jin) |
i'll send it tonight !I can surely wait!!!
C4 | 330µF, 200V, 105°C |
C51 | 2200µF, 10V, 105°C |
C52 | 2200µF, 10V, 105°C |
C53 | 1200µF, 10V, 105°C |
C54 | ? |
C61 | 560µF, 35V, 105°C |
C62 | 82µF, 25V, 105°C |
C71 | 680µF, 16V, 105°C |
C72 | 220µF, 10V, 105°C |
MS9-29 and MS2932 are two completely different chassis.
Not sure if this has been posted somewhere, but this is the cap list for the WeiYa P271 PSU used in the Taito Vewlix, maybe other Taito cabs?
Omron S8XA-531-400 (Jaleco Pony Mark IV)
@ShootTheCore thanks to @nem we know C54 is 1ųF, 50V now.
Thanks a lot for the lists. As a newbie in re-capping it is very helpful to get the right stuff and find motivation to start somewhere.I have compiled lists for two other monitor chassis:
Nanao MS-2934 Capacitor Diameter Qty Location 1uF 50V 5mm 1 C102 2.2uF 50V 5mm 3 C211, C212, C213 10uF 50V 5mm 4 C455, C456, C457, C956 10uF 250V 10mm 1 C322 22uF 50V 5mm 4 C107, C222, C458, C459 47uF 16V 5mm 5 C201, C202, C203, C220, C957 47uF 250V 13mm 2 C512, C952 100uF 16V 5mm 2 C221, C960 100uF 35V 6mm 4 C407, C408, C409, C503 470uF 16V 8mm 1 C402 470uF 25V 10mm 1 C971 470uF 250V 25mm 1 C951 680uF 10V 8mm 1 C955 680uF 35V 10mm 2 C953, C954 1000uF 35V 13mm 1 C406 1200uF 200V 35mm 1 C905
Sanwa 29E31S Capacitor Diameter Qty Location 0.47uF 50V 5mm 1 C103 1uF 50V 5mm 7 C102, C105, C309, C315, C405, C408, C474 1uF 100V 5mm 1 C822 2.2uF 50V 5mm 1 C104 4.7uF 50V 5mm 1 C101 4.7uF 100V 5mm 1 C423 10uF 16V 5mm 1 C839 10uF 25V 5mm 1 C4A7 10uF 50V 5mm 7 C328, C441, C446, C447, C452, C481, C852 10uF 50V Bipolar 7mm 1 C456 22uf 25V 5mm 1 C4A6 33uF 50V 5mm 1 C439 33uF 50V Bipolar 8mm 1 C437 33uF 250V 13mm 2 C426, C831 47uF 25V 5mm 1 C107 47uF 50V 6mm 2 C421, C471 47uF 250V 13mm 1 C107 100uF 10V 5mm 1 C310 100uF 16V 5mm 2 C840, C851 100uF 25V 7mm 2 C306, C429 100uF 35V 6mm 1 C320 100uF 160V 16mm 1 C833 220uF 25V 8mm 1 C305 220uF 35V 8mm 1 C313 220uF 50V 10mm 1 C821 330uF 35V 10mm 1 C427 470uF 25V 10mm 3 C317, C409, C438 1000uF 35V 13mm 1 C835 1000uF 50V 13mm 1 C834 2200uF 16V 16mm 1 C836 3300uF 35V 16mm 1 C314
Sanwa 29E31S | |||
Capacitor | Diameter | Qty | Location |
0.47uF 50V | 5mm | 1 | C103 |
1uF 50V | 5mm | C102, C105, C309, C315, C405, C408, C474, C822 | |
2.2uF 50V | 5mm | 1 | C104 |
4.7uF 50V | 5mm | 1 | C101 |
4.7uF 100V | 5mm | 1 | C423 |
10uF 16V | 5mm | 1 | C839 |
10uF 25V | 5mm | 1 | C4A7 |
10uF 50V | 5mm | 7 | C328, C441, C446, C447, C452, C481, C852 |
10uF 50V Bipolar | 7mm | 1 | C456 |
22uf | 5mm | 1 | C4A6 |
33uF 50V | 5mm | 1 | C439 |
33uF 50V Bipolar | 8mm | 1 | C437 |
33uF 160V | 13mm | 1 | C426 |
33uF 250V | 13mm | ||
47uF 25V | 5mm | 1 | C107 |
47uF 50V | 6mm | 2 | C421, C471 |
47uF 250V | 1 | C107 | |
100uF | 5mm | 1 | C310 |
1000uF 6.3V | 5mm | 1 | C840 |
100uF 16V | 5mm | ||
100uF 25V | 7mm | 2 | C306, C429 |
100uF 35V | 6mm | 1 | C320 -> Couldn't find this one on my chassis. |
100uF 160V | 16mm | 1 | C833 |
220uF 25V | 8mm | 1 | C305 |
220uF 35V | 8mm | 1 | C313 |
220uF 50V | 10mm | 1 | C821 |
330uF 35V | 10mm | 1 | C427 |
470uF 16V | 10mm | 1 | C409 |
470uF 25V | 10mm | C317, | |
1000uF 35V | 13mm | 1 | C835 |
1000uF 50V | 13mm | 1 | C834 |
2200uF | 16mm | 1 | C836 |
3300uF | 16mm | 1 | C314 |
33uF 160V | 10mm | 1 | C433 (was missing on the list) |
Double checked the list while recapping a second chassis. Just some minor updates on the list but now should be complete.I've updated the Sanwa 29E31S spreadsheet with the updated cap information - thanks @meyerli .
https://docs.google.com/spreadsheets/d/1nysqWrW3n-kp-VhbN4LExC1DiPKn8DNiry1igW4O2s8/edit?usp=sharing
Location | Capacitance (uF) | Voltage rating |
C109 | 220 | 16v |
C111 | 10 | 50v |
C119 | 47 | 16v |
C121 | 100 | 16v |
C201 | 10 | 50v |
C202 | 4.7 | 50v |
C210 | 4.7 | 50v |
C211 | 220 | 16v |
C222 | 10 | 50v |
C223 | 10 | 50v |
C303 | 470 | 25v |
C304 | 470 | 25v |
C305 | 220 | 50v |
C307 | 4.7 | 50v |
C308 | 1 | 50v |
C403 | 1 | 50v |
C406 | 100 | 16v |
C411 | 4.7 | 50v |
C420 | 33 | 50v |
C422 | 10 | 50v |
C423 | 47 | 50v |
C427 | 4.7 | 50v |
C430 | 220 | 250v |
C439 | 100 | 16v |
C440 | 47 | 16v |
C441 | 2.2 | 50v |
C446 | 220 | 25v |
C447 | 22 | 16v |
C451 | 100 | 16v |
C452 | 100 | 16v |
C453 | 100 | 16v |
C807 | 680 | 400v |
C810 | 10 | 50v |
C820 | 2200 | 25v |
C822 | 220 | 250v |
C824 | 4700 | 25v |
C826 | 220 | 10v |
C827 | 330 | 16v |
C830 | 100 | 200v |
C831 | 220 | 16v |
C832 | 100 | 16v |
C833 | 22 | 25v |
C837 | 100 | 25v |
C841 | 22 | 50v |
Location | Capacitance (uF) | Voltage rating | Note |
C902 | 33 | 200v | |
C901 | 47 | 16v | |
C917 | 1 | 200v | |
C907 | 1 | 200v | |
C912 | 1 | 200v | |
C916 | 1 | 250v | BP |
C906 | 1 | 250v | BP |
C911 | 1 | 250v | BP |
