SEGA Lindbergh Documentation + Preservation Project - Help needed!
notmurray
Earth
SEGA LINDBERGH DOCUMENTATION + PRESERVATION PROJECT
I've been working on documenting Sega Lindbergh disks and to some extent keychips as well. The aim of this project is to publicly document all the Sega Lindbergh games/disks.
I am aware that there are private versions of this information.... this is a public project for everyone to utilize... BUT... IT NEEDS YOUR HELP!! If you can contribute to this project by helping with missing disk pictures or preserving missing items, then please reach out. Hoping we can crowdsource as many of the missing items as possible, or if you know any missing items and can share those, that will be great.
A massive amount of time and effort has already been put into this project, it's not just a copy paste of all of the available info that's floating around (some of which doesn't seem to be accurate). I have a catalogued folder of everything below that's marked as having disk pictures. Most* of the disks in the table are confirmed to exist, but there may be a few that snuck in there, that do not exist (mainly base versions of games, with no A/B/C revision on the dvd code where it's been assumed there's a base version.). There's more information that can be provided on this table, for now, this is the only info i am trying to put together. See any errors? please post and we can discuss.
HOW CAN YOU HELP?? (the aim is to get all those NO items turned to YES)
INFORMATION:
If you know of a game that exists that's not on the list, please post the information, but i will need a disk photo to verify it's existence. This project is more about being able to verify that something exists, for accuracy. If you can't provide a picture, i will add them to a list at the bottom "unconfirmed"
DISK PICTURES: If you own any of the disks that i'm missing pictures for, and you can take a picture and post it, that would be great. Doesn't have to be anything special, just a pic of both sides to prove it's existence will be very helpful, if you have a pic in your collection of just the top of a disk, then that will also help. The full database of disk pictures will also be made public at a later date, as soon as i can work out the best way to do it. I'm hoping to build something that's searchable and scrollable, but if not i will just post a link with the full picture folder.
KEYCHIP ID's: If you have a game that you know works, and you can provide the keychip code that is printed on the white label on the case, then please post it in the thread.
PRESERVING MISSING ITEMS: If you can assist with any non preserved games, please DO NOT POST ABOUT IT IN THE THREAD.... PM me only. There's basically 2 ways you can assist with this.
1. The simple quick way.(non preferred method)
2. The dat method, where you document the disk and the manufacturing codes on the disk to create a dat file for that particular disk. (this is the preferred way so the item can be properly documented, and all the manufacturing codes on the disk can be recorded, takes a few minutes).
I am happy to walk anyone through this, just pm me.
BE VERY CLEAR ON THIS --- Neither method will allow you to use these games for anything other than installing the game on original hardware WITH THE ORIGNAL KEYCHIP.... So do not ask about playing on emulators etc, this post has nothing to do with that so don't ask. Preserving items will only make sure they are documented for things like mame in the future if they ever get Lindbergh support going, and to keep original machines running for as long as the terrible Lindbergh PC hardware will allow them. PM me for any questions or info about assisting with preserving. Use your common sense and stay within the forum rules... If you are unsure about anything, just dm me first to ask.
Thankfully most of the stuff that's not yet preserved are just alternate game revisions, so for the sake of keeping your machine running if your lindbergh pc dies, there's at least 1 revision avilable for reinstall, but you will of course require your original keychip.
SO.... if you own lindy disks, it would be much appreciated if you can go and check them and see if you can help in any way. If nothing else, then this is hopefully a nice table of items here for reference for everybody. Any other random questions, feel free to DM me. I will probably move onto hardware down the track, but for now the project is limited to whats in the table below. I'll add it to a google sheet when i'm happy the data has been reviewed enough that it's as close to accurate/complete as possible, and most likely a website also.
Thanks to everyone that has contributed so far with getting it to this point. (web posts, pictures, various catalogs of information that's out there, old posts, user contributed info).
You can also email any contributions to lindberghdb@protonmail.com
I'll update the table below if anything new gets found/provided.
HIGH PRIORITY ITEMS (if you own and of these disks and can help, feel free to send a DM)
DVP-0008F
DVP-0010
DVP-0010A
DVP-0010B
DVP-0057
DVP-0057B
DVP-5007A
KEY:
Yellow text means yellow disk (there are some disks that are All Net P Ras, they are noted, but still yellow)
Red text means red disk (there are different versions, they are noted, EX and All Net P Ras)
Blue text means blue disk
Purple title text is used for Starhorse games. Most of the starhorse disks are white, but on this forum the default skin has a white background so i had to pick another random colour, final destination disks are black. Purple text is used for all Starhorse 2 games.
* preserved using method 1 only
^ obtained should be dat preserved soon
? this next to a keychip means it's assumed that it's correct based on the fact that it's been confirmed for another revision of the same game.
MASTER LIST
DVD CODEGAME CODETITLEKEYCHIP IDDISK PICTUREPRESERVED
DVP-0001FSBKMStar Horse 2 New GenerationNONO
DVP-0001JSBKMStar Horse 2 New GenerationYESNO
DVP-0003ASBLCThe House Of The Dead 4253-5508-0427YESYES
DVP-0003BSBLCThe House Of The Dead 4253-5508-0427YESYES
DVP-0003CSBLCThe House Of The Dead 4253-5508-0427YESYES
DVP-0005SBKXVirtua Tennis 3253-5508-0434?YESNO
DVP-0005ASBKXVirtua Tennis 3253-5508-0434YESYES
DVP-0005BSBKXVirtua Tennis 3253-5508-0434YESYES
DVP-0005CSBKXVirtua Tennis 3253-5508-0434YESYES
DVP-0007BSBNCAmi-GyoYESYES
DVP-0007CSBNCAmi-GyoYESYES
DVP-0008SBLMVirtua Fighter 5253-5508-0438YESYES
DVP-0008ASBLMVirtua Fighter 5253-5508-0438?YESYES
DVP-0008BSBLMVirtua Fighter 5253-5508-0438?YESYES
DVP-0008ESBLMVirtua Fighter 5253-5508-0438?YESYES
DVP-0008FSBLMVirtua Fighter 5253-5508-0438?YESNO
DVP-0009SBLRAfter Burner Climax253-5508-0440AYESYES
DVP-0009ASBLRAfter Burner Climax253-5508-0440A?NONO
DVP-0009BSBLRAfter Burner Climax253-5508-0440A?YESYES
DVP-0010SBLSThe House Of The Dead 4 SpecialNONO
DVP-0010ASBLSThe House Of The Dead 4 SpecialNONO
DVP-0010BSBLSThe House Of The Dead 4 SpecialNONO
DVP-0011SBLULets Go Jungle235-5508-0442YESYES
DVP-0011ASBLULets Go Jungle235-5508-0442YESYES
DVP-0015SBMBOutrun 2 SP DX253-5508-0452YESNO
DVP-0015ASBMBOutrun 2 SP DX253-5508-0452YESYES
DVP-0016SBMCSega Network Casino Club STDYESNO
DVP-0016CSBMCSega Network Casino Club STDYESYES
DVP-0018SBMNAfter Burner Climax SDX253-5508-0463YESNO
DVP-0018ASBMNAfter Burner Climax SDX253-5508-0463YESNO
DVP-0019ASBMLInitial D: Arcade Stage 4253-5508-0466J (Server)? 253-5508-0467J Satellite)?YESYES
DVP-0019BSBMLInitial D: Arcade Stage 4253-5508-0466J (Server)? 253-5508-0467J Satellite)?YESYES
DVP-0019CSBMLInitial D: Arcade Stage 4253-5508-0466J (Server) 253-5508-0467J Satellite)YESYES
DVP-0019DSBMLInitial D: Arcade Stage 4253-5508-0466J (Server) 253-5508-0467J Satellite)YESYES
DVP-0019GSBMLInitial D: Arcade Stage 4253-5508-0466J (Server)? 253-5508-0467J Satellite)?YESYES
DVP-0021ASBMCBIOS UpdateYESYES
DVP-0021BSBMCBIOS UpdateYESYES
DVP-0023ASBLMBIOS Update [VTF]YESYES
DVP-0023CSBLMBIOS Update [VTF]YESYES
DVP-0024ASBKMStarhorse 2: Second FusionYESNO
DVP-0024ESBKMStarhorse 2: Second FusionYESNO
DVP-0025SBMSNetwork Taisen Quiz: Answer x Answer [ALL.Net P-ras]YESYES
DVP-0025BSBMSNetwork Taisen Quiz: Answer x Answer [ALL.Net P-ras]YESNO
DVP-0025DSBMSNetwork Taisen Quiz: Answer x Answer [ALL.Net P-ras]YESYES
DVP-0025HSBMSNetwork Taisen Quiz: Answer x Answer [ALL.Net P-ras]NONO
DVP-0026SBLMRouter Update [For VTF]YESYES
DVP-0027ASBMV2 Spicy253-5508-0491YESYES
DVP-0028SBLPTo Ami-GyoYESYES
DVP-0029SBNJGhost Squad Evolution253-5508-0398?NONO
DVP-0029ASBNJGhost Squad Evolution253-5508-0398YESNO^
DVP-0030BSBNKInitial D 4253-5508-0486EYESYES
DVP-0030CSBNKInitial D 4253-5508-0486EYESNO
DVP-0030DSBNKInitial D 4253-5508-0486EYESYES
DVP-0031SBLRAfter Burner Climax SEYESNO
DVP-0031ASBLRAfter Burner Climax SENONO
DVP-0032SBNMClub Majesty: Cosmic ChallengeYESNO
DVP-0032BSBNMClub Majesty: Cosmic ChallengeYESNO
DVP-0032CSBNMClub Majesty: Cosmic ChallengeNONO
DVP-0033CSBNNClub Majesty: Atractive Deck PokerYESYES
DVP-0034BSBNPClub Majesty: Cloud NineYESYES
DVP-0034ESBNPClub Majesty: Cloud NineNONO
DVP-0035ASBNQClub Majesty: Wheel ManiacsYESNO
DVP-0035DSBNQClub Majesty: Wheel ManiacsNONO
DVP-0036SBNRLets Go Jungle SpecialNONO
DVP-0036ASBNRLets Go Jungle SpecialNONO
DVP-0043SBLMVirtua Fighter 5253-5508-0438YESNO
DVP-0044SBPFSega Race Tv253-5508-0504YESYES
DVP-0046GSBPMStarhorse 2: Third EvolutionNONO
DVP-0048SBPPPrimeval Hunt253-5508-0512?NONO
DVP-0048ASBPPPrimeval Hunt253-5508-0512YESNO*
DVP-0049ASBPNSega Network Taisen Mahjong MJ4253-5508-0514 (Server) 253-5508-0515 (Satellite)YESYES
DVP-0049FSBPNSega Network Taisen Mahjong MJ4253-5508-0514 (Server) 253-5508-0515 (Satellite)YESYES
DVP-0049GSBPNSega Network Taisen Mahjong MJ4253-5508-0514 (Server) 253-5508-0515 (Satellite)YESYES
DVP-0050CSBPR SAAKInfo Station 2 **(wtf even is this?)???
DVP-0053SBPWSega Network Casino Club Ver.2YESYES
DVP-0053BSBPWSega Network Casino Club Ver.2NONO
DVP-0054DSBPMStarhorse 2: Third EvolutionNONO
DVP-0057SBQNHummerYESNO
DVP-0057BSBQNHummerYESNO
DVP-0060SBQWR-Tuned: Ultimate Street Racing253-5508-0545YESYES
DVP-0061SBRAClub Majesty: Gatling Poker253-5508-0548?YESNO
DVP-0061ASBRAClub Majesty: Gatling Poker253-5508-0548YESYES
DVP-0062ASBRBClub Majesty: Wally wo Sagase: The Medal YESNO
DVP-0063SBRCLoving Deads: The House of the Dead EX253-5508-0491YESYES
DVP-0066ASBREStarhorse2: Fourth AmbitionYESNO
DVP-0066CSBREStarhorse2: Fourth AmbitionYESNO
DVP-0066DSBREStarhorse2: Fourth AmbitionYESNO
DVP-0066ESBREStarhorse2: Fourth AmbitionYESNO
DVP-0067SBRJNetwork Taisen Quiz: Answer x Answer 2YESNO
DVP-0069SBQLRambo [RED EX]253-5508-0540YESYES
DVP-0070ASBQZInitial D: Arcade Stage 5253-5508-0546J (Server) 253-5508-0547J (Satellite)YESYES
DVP-0070CSBQZInitial D: Arcade Stage 5253-5508-0546J (Server)?253-5508-0547J (Satellite)?YESNO
DVP-0070FSBQZInitial D: Arcade Stage 5253-5508-0546J (Server)?253-5508-0547J (Satellite)?YESNO
DVP-0073SBRVSega Network Casino Club Ver. 3 253-5508-0571 (Server) 253-5508-0572 (Live) 253-5508-0573 (Satellite)YESYES
DVP-0075SBTSInitial D: Arcade Stage 5 EXP253-5508-0576E (Server) 253-5508-0577E (Satellite)YESYES
DVP-0078SBQLRambo [RED EX]YESNO^
DVP-0079SBSTHummer Extreme Edition [STD]253-5640-001YESYES
DVP-0081SBTASega Network Taisen Mahjong MJ4 Evolution253-5640-002 (Server) 253-5640-003 (Satellite)YESYES
DVP-0082ASBSMStarHorse 2: Fifth ExpansionYESYES
DVP-0082BSBSMStarHorse 2: Fifth ExpansionYESNO
DVP-0082DSBSMStarHorse 2: Fifth ExpansionYESYES
DVP-0082ESBSMStarHorse 2: Fifth ExpansionYESNO
DVP-0083Hummer Extreme Edition [MDX]YESNO^
DVP-0084SBTSInitial D: Arcade Stage 5253-5640-006 (Satellite)?YESYES
DVP-0084ASBTSInitial D: Arcade Stage 5253-5640-006 (Satellite)YESYES
DVP-0085Ami No San No.3YESNO
DVP-0086SBUNStarHorse 2: Final DestinationYESYES
DVP-0086ASBUNStarHorse 2: Final DestinationNONO
DVP-0086BSBUNStarHorse 2: Final DestinationNONO
DVP-0086DSBUNStarHorse 2: Final DestinationYESYES
DVP-0086ESBUNStarHorse 2: Final DestinationYESYES
DVP-0087DSBURNetwork Taisen Quiz: Answer x Answer Live [ALL.Net P-ras]YESYES
DVP-5001SBNUWorld Club Champion Football: Intercontinental Clubs 2006-2007YESYES
DVP-5002SBQQWorld Club Champion Football: Intercontinental Clubs 2006-2007 ASIAYESYES
DVP-5004SBQUVirtua Fighter 5 R [ALL.Net P-ras]YESYES
DVP-5004DSBQUVirtua Fighter 5 R [ALL.Net P-ras]YESYES
DVP-5004GSBQUVirtua Fighter 5 R [ALL.Net P-ras]YESYES
DVP-5006CSBMQDerby Owners Club 2008: Feel the RushYESYES
DVP-5007ASBRGHarley Davidson King Of The Road [RED EX]YESNO
DVP-5012SBRLWorld Club Champion Football: Intercontinental Clubs 2007-2008NONO
DVP-5014SBMQDerby Owners Club 2009 ride for the liveNONO
DVP-5016SBTZWorld Club Champion Football: Intercontinental Clubs 2009-2010YESYES
DVP-5019ASBUVVirtua Fighter Final Showdown [ALL.Net P-ras]253-5508-0621J (Server) 253-5508-0622J (Satellite)YESYES
DVP-5020SBXXVirtua Fighter Final Showdown [ALL.Net P-ras]253-5640-008 (Server) 253-5640-009 (Satellite)YESYES
Here's a visual guide to help anyone find the pieces of information on your disks that relate to the table.
UPDATE LOG:
29-July-2025
DVP-0009 After Burner Climax: CORRECTION - Disk status changed to NON PRESERVED
DVP-0015A Outrun 2 SP DX: DISK PRESERVED (method 1)(removed from high priority list) THANKS TO SHARER :thumbsup:
DVP-0019G Initial D: Arcade Stage 4: DISK PRESERVED - THANKS TO SHARER :thumbsup:
DVP-0026 Router Update [For VTF]: GAME ID confirmed as SBLM.
DVP-0070C Initial D: Arcade Stage 5: Previously unknown disk added to the list. Picture confirmed. THANKS TO SHARER :thumbup:
Adjusted the yellow font colour on the table, it was very hard to read on light mode background. It's slightly darker now so it's easier to read, still yellow though.
UPDATE LOG: 7-August-2025
2 rather rare game disks now preserved!
DVP-0053 Sega Network Casino Club Ver.2: Disk Preserved!! DAT method. THANKS TO SHARER :thumbsup:
DVP-0073 Sega Network Casino Club Ver. 3: Disk Preserved!! DAT method. THANKS TO SHARER :thumbsup:
UPDATE LOG: 12-August-2025
DVP-0009 After Burner Climax: Disk Preserved!! DAT method. THANKS TO SHARER :thumbsup:
RANDOM STATS
66 known disks preserved
55 known disks missing
96 pictures of known discs acquired
25 pictures of known disks missing.
Still missing these high priority disks if anyone has them and can help
DVP-0008F Virtua Fighter 5
DVP-0010 The House Of The Dead 4 Special
DVP-0010A The House Of The Dead 4 Special
DVP-0010B The House Of The Dead 4 Special
DVP-0057 Hummer
DVP-0057B Hummer
DVP-5007A Harley Davidson King Of The Road [RED EX]
SEE FIRST POST FOR UP TO DATE LIST
UPDATE LOG: 17-August-2025
DVP-0016 Sega Network Casino Club STD: Disk photo obtained.
DVP-0015 Outrun 2 SP DX: Disk photo obtained.
DVP-0019C Initial D: Arcade Stage 4: Disk Preserved!! DAT method. THANKS TO SHARER :thumbsup:
DVP-0057B Hummer: Disk photo obtained.
DVP-0032B Club Majesty: Cosmic Challenge: Disk photo obtained.
DVP-0067 Network Taisen Quiz: Answer x Answer 2: Disk photo obtained.
DVP-0084 Initial D: Arcade Stage 5: Disk Preserved!! DAT method. THANKS TO SHARER :thumbsup:
DVP-0085 Ami No San No.3: Previously unknown game confirmed, using disk #85 slot. 1 more gap in the numbering revealed!
Thanks to everyone who contributed these, keep them coming!
