FS Stereo + Kick Harness Add-on Boards (Everten)
Pretty sure JNX is drilling that connector out to make it work.
ah, I never noticed that, not a terrible solution, could maybe also look for a 52 position, depin the outer two sets and then add a key pin for extra alignment.
if you find an obsolete part that works but is out of stock check out https://www.utsource.net/ they've got a lot of obsolete parts.
Finally got around to installing this. Love it!
Hello @everten
Please read the following guideline about listing in this marketplace:
Rule 1: Begin the subject of your sale thread with a suffix. For example, if you are simply selling an item you should use the suffix 'For Sale:' or 'FS:'
Thanks so much and let me know if you have any more questions about marketplace policy.
Hello @everten
Do what KLOV did and make tags required in market posts if you want to enforce this. Market policing thread titles doesn’t need to be someone’s job.
Hello @everten
Rule 6: We will not tolerate members poisoning another member's sales thread.
It’s a policy.
It might not be intentional but the rules should be followed.
Please don’t take it personally
Not taking anything personally. Giving honest advice on how to fix the problem the right way.
I love that idea actually.
I think there should also be a trading section as trading would not fall under Want To Buy or For sale.
@brizzo
Is it possible to add a for sale prefix for For Sale posts?
Thanks for your feedback @everten
Installed 😎. Very well designed and easy to install. I’ll definitely be buying one for F3 and MVS when if I’m not sleeping during the window 😅
Could be a silly question but does the volume pot on the STV control the audio volume when using your adapter board?
I’ve finally got around to using my STV with your adapter and it works fine in my Gen 2 big blue, but the volume is max level and I can’t seem to adjust it.
(It could be a faulty volume pot on my board if it is supposed to control the volume)
Thanks
