UD-USB Decoders
I would consult the docs if you can find them, and also I can say a USB A to A cable was recommended from UD to upgrade the devices if/when needed.
May I know how UD-USB Decoders are different from USB2DB15 and CS Ver. for JAMMA/NEO GEO? It appears to me that both perform the same job, which is to bridge usb controller and JAMMA/supergun.
I already did answer you on Discord but to clarify, i think both products do the same when we are talking about use USB controllers and JAMMA/NEOGEO, but with different features.
Hi,
My USB decoder worked fine since 2016 and now I have an issue with one direction (down) all other stuff works fine.
I succeeded in updating the firmware but I still have the same problem :(
Can someone help me ?
Soo it seems like UD haven't logged in here for two years now, i guess we won't see firmware upgrade anytime soon. Did anyone ever tried to tinker with it ? TBH i would love to see it compatible with newer device like the 8bitdo NG controller ...
I sent him a message here as well as a direct email, no response for over a week.
I’m hoping I can find a bunch of the UD-USB Terminal style PCB’s. I’m in need about 6 of them!
Does anyone have an extra one of his db15 to neo connectors? The db15 to 3do converter needs those to make clearance.
Has anyone had any luck getting there's to work with the 8bitdo NeoGeo controller that was recently released?
Will the new firmware be added to the gametech page as well ?
Nice to see you @undamned, hope all is well!
Doing ok!
After you guys play around with the latest Firmware, let me know what controllers you have that are not working.
Already in my queue for next update:
- Sega Astro City Mini arcade stick
- Brook converters (various)
- Microsoft XBOX 360 wireless adapter
Doing ok!
I wanted to test if the 8bitdo 2.4ghz USB dongle (that comes with the M30 2.4ghz version) work with the new firmware since the BT USB dongle is supported now. But I don't have a USB-A male to male for me to update the firmware to test at this time. If it doesn't, is it possible to add this to the next firmware?
Edit: Found a cable to update and test. The 8bitdo M30 2.4ghz USB dongle is recognized by the UD-USB decoder and can connect to my M30 2.4gz controller. But only DPad inputs are recognized and buttons don't. Oddly enough, the 2.4ghz M30 controller can work wired. Please add support for the 2.4ghz USB dongle. Thanks!
