I took mine apart; when looking at the panel in the cabinet, there are 'waves' of dust that looks like burn or dust.Vewlix glass has an anti-glare texture over it, you cannot clean it off.
But you probably have actual dust too, just open it up and clean it and find out. You can't be shy about taking things apart if you're contemplating a monitor swap anyways.
Try a combo of ronsonol lighter fluid and then isopropyl alcohol. That's pretty good at stripping layers of residue without damaging the material.I tried cleaning the glass as much as I could, but there's definitely some sort of residue on the glass/burn in on the monitor or something that I can't get rid of
does the P stands for PIP mode? i didn't even noticed it until you mentioned it I was about to buy itSeems like it. Looks like this is the replacement. Hopefully it uses the same case.I see this monitor now going out of stock in a lot of places. Should have picked it up when it was available for $170! Has it been EOL'd? If so, I wonder if LG's replacement will fit the bracket.
Picture In Picturedoes the P stands for PIP mode? i didn't even noticed it until you mentioned it I was about to buy itSeems like it. Looks like this is the replacement. Hopefully it uses the same case.I see this monitor now going out of stock in a lot of places. Should have picked it up when it was available for $170! Has it been EOL'd? If so, I wonder if LG's replacement will fit the bracket.
That's a reasonable description of my old monitor as well.How bad was your monitor? mine is sharp but compared to modern displays not great colours and some horizontal banding on white backgrounds.
Preorder: Bracket to replace Taito Vewlix monitor with LG 32MP58HQAre these brackets available now?
So- the fans pull in cig smoke and dust, the flor tubes bake the diffusion layer, and age yellows some of the stuff in there. There's a way to clean the stuff- you can get things several shades lighter- but it requires methodical disassembly of the LCD- the LCD layer, the 2 smaller thinner films, the diffusion layer, and the CCFL bulb enclosure. Takes a few hours. If you don't have the patience or the time- the second best thing is removing the monitor, getting to remove the glass and clean the backside. The LCD layer is usually okay-ish.I tried cleaning the glass as much as I could, but there's definitely some sort of residue on the glass/burn in on the monitor or something that I can't get rid of
