Hmmm - well then maybe its the board options I chose (ENIG, gold fingers) - it said they would start building it on the 24th.Awesome work! I believe that JLCPCB will not close during chinese new year this time.
When you say a radius - do you mean to just round the JAMMA gold fingers a little bit?I might recommend some radiuses in the corners, especially on the JAMMA edge. even a 0.5mm radius makes a huge difference.
Also confirm that the total width and other dimensions are in-line with the official JAMMA Spec:
EDIT: a better more readable pic:
no I mean the pcb corners should be roundedWhen you say a radius - do you mean to just round the JAMMA gold fingers a little bit?
Cheers!BUT - at least audio/video/power all came through - so thats great!
Awesome! Please keep us updated.Now I am going to work on hooking up the power from the helper board over to the audio amp board, and the amplified audio signals back over to the helper board and see if that is all working. Then I can work on testing the buttons later this week (hopefully) when I get the button remap switches, as well as testing the seperate line-level audio input stage.
Awesome work. Is this going to be open source?Sorry for spamming this so much - but I just made one more change - curious what all of you who are vastly more experienced than I am at this. I want to make the wiring easier and not have to deal with a spliced connector (since the power amp board just needs 1 5v, 3Ground and 2 12V), so I adjusted the helper board. By doing that, it takes away essentially (2 (top and bottom)) 2.0mm 5V traces and replaces it with a .5mm trace. So the total trace width available for the 5V is 2mm (top and bottom) and .5mm (top and bottom) for a total of 5mm trace width to carry the 5v current. With 2 oz copper, according to claude it says that can carry about 8amp of current, and it figures that the current draw on the ST-V and amp board (on the 5v rail) doesn't go above 6.
Any red flags? Am I cutting it too close?
the 2oz of copper is fine but you're also forcing all of this through the through-holes which can be a bottleneck.With 2 oz copper, according to claude it says that can carry about 8amp of current, and it figures that the current draw on the ST-V and amp board (on the 5v rail) doesn't go above 6.
