beast1x5
i appreciate your attempt.I tried re the selector and STV but bowed out. It's just too many connections that need to be made thus I couldn't achieve a graceful solution that was up to my standards.
Looks great. You need to find a place to mount that dip switch and it will look real clean.Got my PCB in and installed. Looks really clean, fits perfectly with the Highflow plexi case and the stereo sounds excellent. Thanks again @everten!
Looks good, maybe @everten can make a version of his adapter that also has the dips switches for the multi??Still not sure if I want to opt for the LCD solution but I'm happy for now with the dip bank setup. It works and it's easy to use.
Not a bad idea. I may be able fit dips where the CPS1 kick harness is. I could move the CPS1 to same spot as the CPS2 and make it an either/or kick harness. Do a lot of people use remote dips? Not sure it's worth the effort, but I'll look into it if there's interest.Looks good, maybe @everten can make a version of his adapter that also has the dips switches for the multi??Still not sure if I want to opt for the LCD solution but I'm happy for now with the dip bank setup. It works and it's easy to use.
I would say dips were the cps1 kick harness is and move that to the other side next to the rca jacks. i think cps2 kick harness has to be more commonly used over cps1 one nowadays. If there is enough interest ofcourse It would involve adding the dips and the ribbon cable connector. I think it would come in real handy specially when those 90 deg angle cart connectors go on sale.Not a bad idea. I may be able fit dips where the CPS1 kick harness is. I could move the CPS1 to same spot as the CPS2 and make it an either/or kick harness. Do a lot of people use remote dips? Not sure it's worth the effort, but I'll look into it if there's interest.Looks good, maybe @everten can make a version of his adapter that also has the dips switches for the multi??Still not sure if I want to opt for the LCD solution but I'm happy for now with the dip bank setup. It works and it's easy to use.
I uploaded that somewhere, came out pretty decent, I was missing images for a couple of the games. Have there been more games added??I got the dip bank extension from @Mitsurugi-w. The sticker I printed myself from an image floating around somewhere in this forum. It's nice, as each game logo image includes the assigned dip setting for the multi.
Check these:@BroadwayJose @Derick2k do you still have these pics?
