Doh! Forgot to release the video the other day! Here it is:
Evil ! I have same thought.Damn, I had zero upgrade plans but now with that video I might change that...
Thanks for this answer, I thought that was the case but on the highscoresave listing for the new version, it still gives you the option to select PAL-G, so I was getting confused.The new revision of the darksoft kit also eliminates the need to modify the pal. You'll be just fine with your current set up
The LCD is certainly sturdy enough (IMO) without the case, but it's nice to not have sharp pokey bits on the back when you're looking to change games I think. Plus depending on where you're putting the board, the most convenient place to put the LCD might be in contact with metal (control panel, coin door, etc) so the case makes it able to do that.Thanks for this answer, I thought that was the case but on the highscoresave listing for the new version, it still gives you the option to select PAL-G, so I was getting confused.
Do people find the 3D printed LCD case worthwhile? I have the adafruit LCD for my Naomi netboot setup, and it seems plenty sturdy without a case.
~Paik
Yes, get it together with the holster, freakin’ awesome and compact setup once fitted;Thanks for this answer, I thought that was the case but on the highscoresave listing for the new version, it still gives you the option to select PAL-G, so I was getting confused.The new revision of the darksoft kit also eliminates the need to modify the pal. You'll be just fine with your current set up
~Paik
