Good evening everyone
I am back with the same issue. I am sorry Darksoft.
First I tried the new PSU 9V 2A center negative with some original games , no problem.
Then I used the card with the old fw r_966 and menu_20190401 which was installed from last time. I erased a game from last time slot1 and add new one keeping the 2 other on slot 2 and 3. I played a little bit and try to change by removing first the present game and add the new game, it is written "please wait" and black screen, I am waiting 10 minutes but still black screen, and I need to switch off the console wait for 10 minutes and switch on again, some message like checking games, then restoring are written successively and then the menu starts normally. I tried to remove the games and add one only on the slot 1. Still It is the same : "please wait" and then nothing black screen. I always feel like there is something missing, a file or something else ?
I tried the new FW_1169 and menu_1122 by keeping the structure on the sd card, keeping the games file and update. I update unzip the FW and and the file menu containing the files from the menu. I add this in the multi card, It performed the installation normally, when the menu starts I went to check the "diagnostic" and "about", apparently no problem. I installed one game on slot 1 and played a little bit, went back to the menu bit simultaneously pushing up and start, It did worked so I switch off the console, wait a little bit and switch on again. The menu starts I tried to remove the game and install another one, and still the same "please wait" and then nothing.
The only thing I did nt change is the set of games rom, is it possible to have such issue from it ?
I dont know what to do, please if you have some idea tell me
thanks
